severus
I built an ITX machine for a friend consisting of
G3258
GA-H97N-WIFI
8gb DDR3
HIS HD7950
Corsair H60 w/ aftermarket Corsair fan
Silverstone SG13 case
Here's the problem. The H60 reads 4000RPM's in the Bios, but when I monitor the temps, the idle creeps up from the initial 60° to 100° and sits there. Sometimes I hear the coolant flowing through the unit, a lot of times I don't. I've tried remounting the cooler but no dice. The board only has a CPU and SYS fan header. Perhaps I should try a 4pin to Molex so the unit can draw power directly from the PSU?
My hypothesis: being an H97 chip instead of a Z series, and since the board only draws from a 4 pin connector, it's not supplying enough power to make the pump actually work all the time, or does this issue sound more like a faulty pump?
G3258
GA-H97N-WIFI
8gb DDR3
HIS HD7950
