I'm running Windows Home Server. Since I want to leave this machine on most of the time, I am looking for a somewhat modern setup with the least power consumption. Because this will basically be a file/print/backup server, it does not need a ton of horsepower. Here are my current thoughts for a system. I'd appreciate your input.
- CPU: Sempron 3400+ Manila. This CPU has a very small TDP (35W) and only one core sucking power. It is also cheap at less than $30.
- Cooling: Should I just use the stock AMD HSF?
- MOBO: AM2 with integrated video. I've read that integrated graphics use less power than PCI-E cards. Also, integrated graphics usually don't use fans. So, there will be less noise and power consumption. I considered a 939 board, but DDR RAM is so darn expensive these days.
- RAM: 2GB DDR2 RAM (2 x 1GB) DDR2 RAM is so cheap that I may as well get a decent amount.
- Optical Drives: None (Just use an external drive to install WHS).
- Hard drives: 2 x ATA 400GB, set to idle after 15 minutes
- PSU: I have a few of this model around. LINK It is cheap, relatively quiet, and has been rock solid in three other systems.
- Other: Undercloking: can it be done with this CPU by lowering the multiplier?
