[semiaccurate] Coffee Lake points to issues with Intel’s 10nm process
DrMrLordX
23,141
13,234
640 and 650 you mean.
Yeah sorry, got my numbers mixed up.
Man what a shame: 6 core + eDRAM could have been a nice option against Zen/Zen+ on mainstream desktop.
That's exactly what Intel should have delivered with either Kabylake or Coffeelake. They're providing half with Coffeelake so it isn't a complete bust, but still . . .
So do you lose the benefit of e-dram as a cache if you add a dgpu?
No.
mohit9206
1,381
511
Should we blame Kraznich or AMD? Maybe Zen will light a fire under his arse and we get more than the 5% annual performance increase that Anandtech loves to call " The New Out-of-the-box Performance Champion".
jpiniero
17,036
7,424
BK said they are cutting back on PC R&D. Zen's not going to change that.
Ajay
16,094
8,114
That could change, depending on what AMD/Zen brings to the table over the next few years. It doesn't make sense to change that strategy now - the impact of Zen is an unknown.
Qwertilot
1,604
257
Can't see that myself - medium term its a commodified market, so near dead by Intel's standards. Any R&D response now obviously wouldn't appear in products for quite a while, by which time it may well not matter.
They're obviously not going to stop or slow down in terms of server chips though.
2,012
At a recent investor conference, the head of Intel's PC group said they didn't cut any significant programs in PCs. The cost reduction was mainly site consolidation and moving to lower cost geographies.
2,012
Server chips use the same cores/IP that are used in PCs. Cutting back on CPU core development would hurt server, but Intel says it's increasing investments in servers.
Intel isn't cutting back its CPU core investments.
itsmydamnation
3,097
3,941
But the cores are diverging (avx512), i assume the laptop and desktop parts will keep the ringbus and the big server SOC's move to the new fabric etc.
Reactions: Drazick
2,012
The cores are diverging somewhat but even SKL Xeon is based on the fundamental Skylake core with some modifications/addition.
If you cut back R&D on the fundamental cores, you don't have as strong a foundation to work with for server. This is an area that Intel has been frantically investing in (servers) so they will want to do everything in their power to keep cores hyper competitive.
itsmydamnation
3,097
3,941
if they make the server core a true 512bit wide core then they massively diverge, almost everything has to change and if they implement non mirco coded scatter gather then cache and load store will have to be very very different.
Reactions: Drazick
Spartak
353
266
If you put Intel's main CPU architectures next to its last two CEO's you get a rather worrisome picture.
Otellini CEO from 18-05-2005 to 04-06-2013
in this timeframe we saw:
the move away from Pentium and Netburst with Core branding and Yonah (jan 2006)
then the ground up Core design with Conroe (jul 2006)
then we got SMT with Nehalem (nov 2008)
Sandy Bridge (jan 2011)
Haswell (debuted 04-06-2013...)
For anyone saying Conroe was in developement for much longer than his tenure as CEO, yes indeed and Otellini was one of the driving forces behind it. Haswell was his final, goodbye tock.
Krzanich CEO from 04-06-2013 to present:
....still waiting for something substantial.
And this is just architecture. On process there are many physical problems to solve (EUV not ready yet etc.) so you cannot blame it all on one person, but it's remarkable that Intel was able to execute flawless up to 22nm FinFET (which was no small feat!) yet stumble so bad on 14nm through 2013-2015 and now again on 10nm if we believe the whispers coming from Intel.
If you ask me, every month with Krzanich will be a lost month. And if this guy stays on much longer, he's going to do irrepairable damage with everybody moving to ARM even for HEDT. AMD's K12 and MS UWP/WoA already lay the groundworks for this move away from x86. Jim Keller already made some hints about the IPC potential of the ARM architecture.
Reactions: Dave2150
2,012
For anyone saying Conroe was in developement for much longer than his tenure as CEO, yes indeed and Otellini was one of the driving forces behind it. That's also why I included Haswell with Otellini, it was has final, goodbye tock.
There has literally not been a "tock" developed under BK's watch released in the market yet. Everything we are seeing was greenlit by Otellini.
NTMBK
10,497
5,947
Given that ARM is a RISC architecture, does it not need higher IPC or clockspeed in order to match CISC performance?
Spartak
353
266
It's not so much more instructions (which is inherent to RISC) but what I meant was more powerful/efficient operations per clock. Performance per clock (PPC) if I might coin a new term.
Apple's A10 already has higher ST performance per clock versus Skylake according to Geekbench. I'm expecting the K12 to match that.
beginner99
5,320
1,768
It's always easier to get high IPC at lower clocks. Call me again when they achieve this at 4 ghz (or 5 gz OCed like Kaby lake).
Lodix
340
You are talking like if they didn't take in count power consumption at "lower clocks" in a mobile SOC when Intel couldn't get even close to this efficiency curves with an advantage in manufacturing process.
beginner99
5,320
1,768
I'm not denying that. But it is something completely different than what I said. Just because you can beat Intel at IPC (at low clocks) doesn't mean you are ready and can easily deliver an ARM based competitive desktop/Server CPU. This ARM in server thing has been around for very long now and still nothing. The ones that actually shipped a product failed.
I mean if it was that easy do to so, why hasn't anyone done it? I'm not an Intel fanboy but this "ARM is catching up" thing is getting old. I will for example upgrade by PC soon and if it is a 7700k or Ryzen, I will know soon enough. I also know for my workloads I rather get 20% higher ST performance (OC included) than better MT performance.
Dx12/Vulkan only games built on a new engine from scratch without legacy support (eg. no compromise) are still years out. Then MT will matter for gamers. Now a fast Quad still rules. Especially for certain games...
Reactions: CHADBOGA
