Selling my rig, need advice.
atybimf
2,390
Well, the time has come for my first car (yeah, I'm young) and I need money. My parents aren't the type to buy me things I don't need (yup, I had to buy my current rig myself) so they said I'd have to pay for my own car. So I have to part with my beautiful machine. Here's what I was thinking about price wise if I parted out:
Opteron 165 - $250
DFI Lanparty - $70
Sapphire X1900XT - $375-$400
Mushkin XP4000 1x1GB - $80 -$90
Antec TX1050B case and Antec SmartPower 500W - $100
BenQ DQ60 - $25
Western Digital 160GB - $45
Total: $945-$980
So I think when I said $900 for the whole thing I was being pretty reasonable.
Cinna696
165
if you part it out it will take longer to sell it in its entire. however you will probably not get as much $ if you sold it as a whole unit but it would be all done in one sale and not be as much of a hassle as parting out
secretanchitman
9,352
23
i would sell it all in one go. seperate components will prolly have more hassle attached to it.
my two cents.
LOUISSSSS
8,771
58
if you asked me how much i'd give you for that rig at stock speeds never overclocked i'd give you $800, but since you've must've played with the voltages and clock speeds of everything i'd give u $650... since i can't guarantee the parts will last too long and prob has no more warranty
atybimf
2,390
I guess I should mention it wasn't at 2.7ghz 24/7. I just got it to 2.7ghz in testing. The video card was on stock volts so it's fine. I was thinking more around $900-$1000 for the whole thing. Dunno though.
allanon1965
3,427
Price checks are not allowed, but I am of the opinion you are asking way too much...used computers, especially on here, dont go for alot.....probably would do better parting it out either here, or ebay...
LOUISSSSS
8,771
58
yea but just the fact that you changed stock speeds voids warranty = huge decrease in value.
and you pushed it hard and might have tried even harder before getting it stable.
yea not that i think about it i'd doubt i'd pay more than $500-600 for it
LittleNemoNES
4,142
I would just keep it. Just add another month of savings on there and you will have a car and a nice PC.
atybimf
2,390
Am I really overestimating it that much. I mean I could probably get:
Opteron 165 - $250
DFI Lanparty - $70
Sapphire X1900XT - $400
Mushkin XP4000 1x1GB - $90
BenQ DQ60 - $25
That right there is $980 if I parted out and all at pretty darn good prices. I'd think I'd be dumb if I went any less than $900
Powermoloch
10,084
4
Opteron 165 - $250
DFI Lanparty - $70
BenQ DQ60 - $25
I learned the rule of thumb on used stuff...multiply the original cost by 65% - 70%. As an example, I got my Mushkin XP4000 for 199.99 - 40 AR : 159.99 (rebate is on the way). I really don't want to thread crap, but $ 90 per stick is iffy.
LOUISSSSS
8,771
58
i wouldn't give u $400 for a used x1900xt overclocked to its max. OR 250 for an opteron overclocked to its max. ram def not. and case and psu i'd buy for $30.. used stuff doesn't go for that high...
NuroMancer
1,684
No actually,
The posters in this thread are only giving him an idea of what kind of questions he can actually expect to get when selling his rig. He decided to OC his rig as much as possible even if it was only for 24 hours, which I doubt is true.
While some of the prices are slighty low balled, I think you might be able to get 700-750 for it if ur honest and sell it as overclocked. Maybe not.
LOUISSSSS
8,771
58
if we wanted to buy it from him we would have PMed him already. OP did u get any pm from us regarding buying your pc?
Jun 14, 2003
10,442
jus get a bike mate.
though some sucker on ebay will probably pay over the odds for this, if you glam it up in the item description.
if you got the gift of the gab, you could probably sell turds on ebay
Jun 14, 2003
10,442
he doesnt have to tell the egayers that
aigomorla
21,070
3,575
he's trying to flame you on the price. Honestly opty's 165 have known to overclock with little to no voltage increase. As long as you werent running the voltage at 1.55+ for the entire length of time, your cpu should last you longer then the average upgrade period.
ALSO I WOULD LIKE TO NOTE, AMD REQUIRES YOU TO RETURN YOUR STOCK FACTORY HEAT SINK ALONG WITH YOUR CPU IN FILING FOR RMA! So that basically means if your using a aftermarket cooler, and your stock cooler is in essense immaculate, they will automatically ASSUME u overclocked. My friend got screwed like this when he replaced the HSF for a quieter one, and had hell fighting with CS at AMD.
LOUISSS are u using the stock heat sink???? If not u better pull the thing out of the closet since ur so worried about warrenty.
Also his price check makes ABSOLUTELY NO SENSE. The video card alone will sell for 375 at the cheapest value and the rest of the components will total WAY more then $125.
Also if you have proof that your cpu will clock to 2.7ghz with little to no voltage increase it will ACTUALLY INCREASE ITS VALUE. People are always looking for golden pick chips and a 2.7ghz on little to no voltage increase is definitely a golden chip. So dont let him try to whimp your way in getting a fair price.
Honestly, when parting a opty with board and ram, its best to see how far it will go with no voltage increase. If its stable at 2.6-2.7 like my X2 on near stock or stock voltage, id say asking 1000 is perfectly reasonable. If your chip requires major amounts of voltage to be stable at 2.6 or 2.7 then 800-900 seems about right.
PS what kind of DFI is it? LP SLI-DR? or SLI-D?
atybimf
2,390
It is an Ultra-D. And the most volts put through the processor was 1.45v to reach 2.7ghz. the rest of the time it was at 2.5ghz with 1.3v.
atybimf
2,390
LOUISSSSS, to what is the extent of your online trading experience. $30 for the case and psu! Its a nice big case with a 120mm fan and the psu is a 500W modular from a reliable maker - antec. lol.
aigomorla
21,070
3,575
2.5ghz at stock volts is concidered a decient/really good overclock at stock voltage. So yeah, id push retail on the opty. Even then there still getting a good deal. Try to look at the steppings on the cpu. If its the golden pick steppings, u could even push a little more.
Remember when people expecially on the forums looks for a processor, the first thing they ask is WHAT ARE ITS STEPPINGS!?!?!?! if its a VPWM, then i know a few people on forums that would pay retail for it hands down.
Also as much as i hate bashing people, dont listen to louissssss, as i stated, he's trying to flame your price, he's throwing things like warrenty at you, when he himself have voided his own warrenty according to AMD standards.
Also i figure were big boys now, if we break something because of our mistake, we bite our tonge take a deep breathe and hit the for sale/trade forums for a replacement :X
LOUISSSSS
8,771
58
i've never changed clock settings and my stock cooler is being used in my friends system. i dont see a used overclocked abused video card valued at $325 here... i wouldn't buy a new antec for $30, why would anyone buy it used for a while on an overclocked system in a poorly ventilated case for anything more than $30. gl selling your parts.
aigomorla
21,070
3,575
Where the heck are you getting these assumptions that he overclocked it to the MAX? He never stated he even OVERCLOCKED his videocard just his processor. And 1.45V is nowhere near the max OC for that opty. Ive seen optys run stable 24/7 at 1.53V for months, since there first release.
Why are you flaming the poor dude. He has one of the high end systems on this forum. His processor is probably in the same par as my X2 in overclocking room, and definitely his processor will EAT your 4800+, as will my X2. Ive gotten as high as 3.2ghz stable 1 core and 2.97 stable both cores at 1.57V. And i bet you with my liquid cooling and IHS removed, its probably way more healthier then your scythe 4800+. I idle at 23 and max at 27. Whats your temps? And yes i know temp's and voltage are two different things, but chips die faster with heat then voltage, unless your really stupid and decide to push 1.7+V on that chip.
BTW my summer config thanks to cmos reloaded is 2.4ghz at 1.18V. Can your chip do that with 1.18V? THATS 1. LESS the standard factory voltage. 2. my cpu is kept below 30's at full load. Can you still say your CPU is healthier then mine?? oh wait you're goign to probably bash me because i removed my IHS.
Anyhow, as someone stated in the above thread, unless your looking to upgrade to a conroe after you get your car, i would just keep the system, and save up. Chances are you probably wont ever need a new computer until you either goto college, or your junior yr in college.
And LOUISSSSSS u still voided your warrenty by seperating the HSF with the CPU. So regardless to the fact, if your going to be that strict on the poor kid, THEN YOU VOIDED YOUR WARRENTY TOO SO YOUR CPU IS UTTER CRAP! But if it does happen to break, you'll probably take back your HSF, and mail it back to AMD, which in hence your cheating the Warrenty guidlines.
Also OVERCLOCKING IS A HOBBY, looking at the sheer fact in the components he chose, they're ALL routed with 1 thing in mind, OVERCLOCKING. Well maybe not the PSU :X
Also i find it not a problem that i paid 320 dollars for my X2 when it came out, you paid 700 for your 4800+, yet when you compare our system, my system has headroom to go as high as 2.8ghz both core stable with 1.47v and your's is cap'd at 2.4ghz stock at 1.35V. The op probably had the same concept in mind, get a system that has a high room for overclocking, because in this century, i dont think i'll end up keeping this system for another 2-3 more years max.
I really dont see the point in not overclocking unless your going to be doing intensive checksum's and server build. Then you dont want to overclock, but were looking at a perspective on a kid thats 16 yrs old. Hell when i was that young, even then i still overclocked the celly's 300A to 450mhz, and it never died on me. And just to let you know, there is a noticible difference from 2.8ghz --> 2.4ghz.
So please leave the poor kid alone, he has a great system, and his cpu will fetch him near retail if not more, i would still suggest checking the steppings on the cpu. If its VPWM, then you can even expect a little more then retail.
Anyhow good job at working for your own car. :]
LOUISSSSS
8,771
58
i actually got both my 4800 and 1900xt for free. how much did u pay for yours again. i really did get mine for free. i even got head for going to my ex to pick it up from her and not having her bring it to me. i'm sure i can bring my cpu back to amd with my stock cooling as long as i dont have ay burn marks on my cpu. yes your 3800 is better than mine lol. thats what all poor people like to believe. yes overclock. why overclock if you can afford a better cpu? and run it stock. why buy a ford focus and add a bunch of engine mods to it and change the exhaust when you could have just bought a viper? "cuz its a hobby" or you couldn't afford it. you can remove your ihs all you want. i think i'd rather like my processor intact where i can ensure no problems. oh yea she got me the scythe ninja too along with the 150gb raptor. so i really only paid like $500? for my system? overclocking could very well be a hobby. would YOU buy his system for $900? even if you didn't have a computer? really.. think about it. all used parts, F*ed around with and can very well be damaged and you OR the op wouldn't know. i know i wouldn't but then again, the poor person's route would be to say yes and buy used parts.
as for OP, let us have an update as what you plan to do with it, sell it as a whole or part it. or keep it. but how much would $500 or $1k help you in purchasing your new car?
ever think abuot keeping it? and saving for a car
