Good day gentlemen. I hope this post is in the correct forum. I was wondering what you guys opinions are on bike gear systems, specifically one that is well known for being simple and reliable. I currently own a Walmart bike which is fine for getting around town, especially on pabike lanes and the many paved bike trails in Colorado. However when I ride, I stay in the first three gears always. I switch the first set of 3 gears but I don't like to switch up to the 2nd set because it's hard to get back to the first gears (it's a cheap bike).
I want to do some long distance road cycling. My long term goal is to ride from Colorado Springs to Denver by bike. Currently, the bike I own doesn't inspire much confidence in me because the chain and gear system feels cheap and looks difficult to work on.
So I wanted to ask, can you guys recommend a particular gear system (eg, Sturmey Archer) that is simple and sturdy? I'm asking in hopes that I can learn much more about my bike, take off the chain and clean it periodically, and go on long distance trips where I can shift into a higher gear and maintain speeds around 25-30 mph.
Like I said, I'm really wanting to stay away from the more complex systems. Something that is well built and perhaps lends itself to self maintenance. I'm looking to buy a bike for my birthday in October and my budget is $400. I don't need an aluminum frame, disc brakes, or even shocks, since I plan to stay pretty close to paved trails and bike lanes. The only thing I really need in a bike is a sturdy gear shift.
Thanks for any and all help! 😀
