Seeking help with my first AMD 64 setup
buildingacomputer
281
I understand AMD 64 Venice 3000 has x9 multiplier and 1.8 GHz. My mobo boots with x5. I entered BIOS setup and changed it to x9. Rebooted. Ran CPU-Z. It went back to x5.
After a while, I found I can go up to x7 and 1.4GHz. For x8 and x9, it changes back to x5.
I am not overclocking. I am trying to get the full power I paid for.
CPU frequency = 200 (I didn't change this)
Hammer Fid control = x7 1.4GHz (cannot go over this)
HT frequency = Auto (ranges from 1x to 5x)
PCIE clock = 100 (I didn't change this)
Memclock freg = 200 (I didin't change this. Kingston ValueRam PC3200)
Do I have a bad mobo?
Supershanks
61
Don't know that mobos bios but a couple of things spring to mind:-
1) Cool'n'Quiet - works by dropping thecpu mult to 5 when cpu is idlle/cool - disable any cool'n'quiet features u see in bios.
2) You did save bios changes b4 exiting bios. - Sorry don't mean to insult u but am unaware of your knowledge.
luck
buildingacomputer
281
Gentelmen,
You were right. It was the Cool Thingy. Thanks. I thought I bought a lemon mobo.
I was going to overclock it but I don't see a need to do that. I have no program that pushes CPU to the full x9 speed. I am going to kill the fans to low speed and make it a quiet PC. Thanks again.
Markfw
May 16, 2002
27,429
16,297
hey, in that case, enable cool and quiet. You will get the speed when you need it, and it wil be even quieter at 1 ghz.
GuitarDaddy
11,465
Yeah I use it constantly, and if you use a utility like RMclock you can control when it throttles and how much. Saves electricity, runs quiet, and even works with overclocking. Mine 3700+ currently runs 2.8ghz when under a load and 1.5ghz while idle.
Does it work well with X2's?
