BonzaiDuck
I'm sitting here with a now-dated Sandy Bridge system which actually "evolved" since summer, 2011. Tweaked and tuned, I didn't need water-cooling then to keep temperatures manageable at variously 4.6 and 4.7 Ghz, and I don't need to do anything with it now. A colleague of ours, who may go by the handle of 996GT2 now, had a similar rig with the 2700K CPU under custom-water cooling. He's been able to achieve 5GHz, but for 24/7, he said he ran it at 4.8.
Now I'm counting my Quicken accounts and putting together a plan to build a Haswell-E system next year. It will likely use the i7-5820K or i7-5930K processor. These "E" cores are still apparently fabricated with indium solder, no less because they have a TDP of 140W!!
There seem to be early indications that you can overclock the 5820K to 4.4Ghz with a CLC or AiO cooler -- without raising the VCORE and boosting temperatures into the stratosphere.
Someone else spoke of 4.6 to 4.7 Ghz with custom-water cooling. Of course, until I see some discussion in these forums, other sources such as early customer-reviews at the Egg are sketchy.
I have a choice of using either the NH-D15 air-cooler, a top-end CLC or AiO cooler, or custom-water cooling. Comparison reviews such as I've found at Frosty Tech standardized with a "200W simulation" show such units as the Nepton 280L with just a 5+C degree edge over the NH-D15. I believe, with my homegrown techniques, that I can match that difference and get better results for the D15 than reviews show. Other coolers, like the H100i don't seem to show any better.
I'm looking at custom-water kits. I figure, rather than ordering individual parts with no scars of experience and experimentation, it would be better to buy a kit and then add modifications or improvements later.
996GT2 seemed to indicate his 2700K rig would not exceed 50C with his water-cooling system under stress testing. My current rig reaches (average-of-cores) 72C with a 78F room-ambient.
Perhaps someone can recommend a custom-water kit -- Swiftech, AlphaCool, Phobya, Koolance -- or anything else.
I'm not so inclined to build a dual-loop or use it for the GPU(s): I think the new Maxwell cards will make air-cooling just fine for that.
If there are recommendations forthcoming, perhaps I could get an assessment of "weakest parts" included in the kit, or what I might expect after over-clocking a 140-Watt-TDP processor with it.
This will all drive my choice of a computer case, and I'll get to that bridge when I cross it.
Thanks.
PS. Price is not the primary consideration. In fact, it's the least important factor. The kits I've seen don't seem to exceed a distribution of prices with $400+ beyond the upper tail.
Thanks.
