Originally posted by: Shaq
Originally posted by: Idontcare
Originally posted by: error8
Originally posted by: Assimilator1
Not according to Intel - Q6600 G0, safe to 1.5v, temps allowing. (saw your qualifying statement in a latter post but left the link in for info ).
According to this it's at 1.55 V. I'm feeling happy at 1.52 V in bios and 1.45 V under load with my q6700.
Yep, the max VID is 1.5V, that doesn't mean the CPU cannot operate on higher Vcc and still be OK and within warranty/spec.
Max VID just means Intel won't sell a G0 with a default Vcc requirement under load that exceeds 1.50V. VID range != spec limits.
Does that mean i7 is okay up to 1.6v? Check out page 15 on the link.
http://download.intel.com/desi...or/datashts/320834.pdf
No, that simply lists the addressable range of VID settings which Intel has programmed, it doesn't mean it actually intends to use the entire range or that the processor line is compatible with the entire range of values represented in that table.
However the max Vcc is stated in that document, top of page 22, and it is 1.55V for the i7.
Further, for the i7 the VID range is 0.8V to 1.375V...see top of page 23.
And in standard operating conditions the maximum allowed Vcc overshoot is VID + 0.05V (happens when the processor goes from loaded to unloaded condition)...see page 29.
