- Jan 4, 2001
- 41,599
- 19
- 81
I'm looking for a replacement UPS for an old machine, but there are some dimensional restrictions, and I want pure sine wave output.
Other necessary feature: Ability to configure the UPS to turn itself off after 2 minutes without the need for a PC to remain connected.
- I've found that modified sine wave UPSes have differing outputs. The old unit's peak-to-peak output was about 300V. A TrippLite unit I tried was putting out close to 380V pk-pk, but the duration of the on-time is shorter. The machine doesn't like that voltage; it likely gets rectified and filtered, and the resulting voltage is probably too high so the machine errors out and shuts down that subsystem.
If I run the machine directly off of sine-wave line voltage, it works perfectly fine, so I think it's that excessive voltage peak that's tripping it up.
- There are dimension restrictions, and no UPS manufacturer or seller lets you sort by dimensions.
15" long x 6" wide x 3.5" thick
I think I could manage 4" thick if the outlets are on the back, not the top.
- The original UPS was only 300VA, so I don't need very much.
Does anyone happen to have come across a reasonably-priced slimline UPS with sine wave output?
(Or else a modified sine wave output that is only 300V pk-pk, which I'm sure is a spec that's even more difficult to find.)
Search tools on popular UPS makers (that I know of) are surprisingly limited, APC in particular. TrippLite at least offered numerous filters. APC offers very few, and the type of sine wave output isn't one of them. With them, you can filter by load, voltage, and runtime. That's about it. Some manufacturers don't even list the type of waveform their UPS produces.
