Searching for Information
Nice biology links, they have been added. And I will now have quality ebooks for my TI-89 titanium :thumbsup: Thanks goes to the moderators, now I don't have to search for this thread!
Just thought I'd bump this with a tip:
On google, if you need to do a conversion, type something like:
45.67 miles = ? cm
And, it'll do the conversion for you. No need for a special website.
45.67 miles = ? cm
And along with that, google features
Cannot believe nobody has mentioned Dogpile.com yet. :Q
Why limit yourself to just Google, Yahoo, Ask, or many others, when you can use a Metasearch engine like Dogplie to use them all at once?
45.67 miles = ? cm
Neat ^
Text
45.67 miles = ? cm
It's even smarter than that. You can just type
45.67 miles in cm
and it'll give you the right answer.
It also knows a lot of physical constants. Try typing in:
(mass of electron) * c^2 in MeV
It'll give you the rest mass of an electron
Of course you could just type in
mass of electron in MeV/c^2
to get the same thing. Actually, google calculator does a lot of cool physics stuff. I use it in the lab all the time.
http://webbook.nist.gov/chemistry/
This is an *amazing* reference of thermophysical properties of chemicals. It has data compiled from the research of different scientists, as well as references. For example, it will tell you the heat capacity of a liquid and then the range of temperatures it was tested at, and then the names of the researchers and when they tested it.
I used it in one of my classes to find things like:
Boiling temperature
Heat of vap at boiling
Antoine's constants
critical temp/pressure/volume
etc
Nice list. Most of the sites I have in my favorites are too specialized, but I'll have a look later to see whether I have some decent ones too still.
