MMHighPoint
I'd like to order a new computer and replace the case fans with quiet ones. There are only a couple of serious comparison reviews on the net. They seem to point to Scythe S-Flex or Gentle Typhoon, yet newegg shows these fans as out of stock even though they have 5 star reviews. Even more ominously, scythe's website just says "discontinue." Will there be new models or am I screwed?
Can anyone recommend good, quiet 120mm case fans?
Will a 220mm case fan get quieter if it is slowed down or will it tick or make some other annoying noise?
Thanks
Thanks
