sharkeeper
Unless that is a solid state drive shuttle, the access time benchmark is bogus. Pure and simple. RAID does not shrink platters or increase the speed of the read heads, so it cannot improve access time benchmarks which test the entire surface of the drives. It can improve access time over a given capacity, but it cannot improve access time over the entire array.
The results are real. The controller runs the entire test in its cache. Controllers with 2+GB of cache are around the corner so this is like a SSD but better, more capacity and affordable with redundancy to boot. The test system uses 512MB of PC2700 DDR ECC cache with a battery backup. Disk activity is practically nil even when virus scanning!
If the test is run with the cache disabled, the access times are 4.8 mS which is close to the physical specification of the disks. RAID10 shaves a full mS the results. Not nearly as effective as the cache. Even running a single drive has a huge benefit with the cache ON. The only bad thing that could happen is the battery spoil and someone trips over the power cord while doing a defrag. (I've tested under these conditions for the exception of the tripping part and the OS was fuxored.)
Cheers!
