Okay, so here is the dilemma. I finally decided SCSI, here I come. I just bought the hard drive from a reputable guy on eb*y? here?s the link:
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=442292848
The controller card is what has me worried. I got sort of a no name controller off of eb*y because it was cheap. Here?s the link:
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=445625175
Now I now the drive and the controller card are compatible, Ultra Wide 2?. But since it is a no name brand controller I?m sorta nervous at what kind of performance it would be. It is a symbios chipset though? I think. I also bought the SCA to 68pin adapter with terminator and 68 pin cable with termination from compgeeks.com Does the 80 pin adapter cause a performance degradation? Am I doing the right thing here? I was gonna buy the sexy new IBM GXP45?s but I really wanted to go Scuzzy because I used to have a SCSI burner and that thing ruled, never locked up the computer when accessing as IDE CDROM?s do?
And here are my system specs if its helpful. I really appreciate any advice or comments you scuzzi gurus can provide?. Oh, and don?t bother with the IDE vs. SCSI unless your gonna praise my decision. Thanks.
P3-550E OC?d to 733 (PCI & AGP bus still at the same speed)
Asus P3V4X 1004 Bios
128MB PC133 CAS2 Mushkin
Geforce SDR 32
Promise Ultra66
IBM Deskstar 10gig 5400 (ata66 I think)
Maxtor 36gig 5400(ata66)
SB LIVE
Panasonic DVD 5x
HP 32x8x4 burner
Minidisc digital interface
Two Netgear NICS ?100/10
Geforce SDR 32
Promise Ultra66
SB LIVE
Panasonic DVD 5x
HP 32x8x4 burner
