I bought a SCSI DVD player (Pioneer DVD 305 S) and set the jumpers to SCSI ID 2 and termination on. When i boot, the computer locks up at the SCSI BIOS... If i enter the SCSI BIOS and do a scan, it locks up while checking ID 2...
I'm using an Adaptec 2940 SCSI Adapter, the Host Adapter is set to ID 7 with termination enabled. The DVD drive is the last device on the chain, no others on the chain. There's also a jumper to set sector size, either 2048 or 512. I've tried both to no avail, wouldn't imagine that'd be causing the problem though.
Thanks in advance
Thanks in advance
