- Jan 10, 2001
- 30,772
- 13
- 81
Took the Jeep out for the opening weekend of offroading at the Mounds ORV park in Mt. Morris, Michigan. After 4 hours of pretty hard driving, it started overheating, badly. I turned it off, dumpe about 2 gal. of water on it and let it sit. About 30 min later, drove it around and it was still overheating. Took it to the parking lot, cleaned out the radiator and let it sit for an hour. Came back and was in the process of going to the nearest carwash to clean the engine bay when i noticed that it was at 4000RPM at 35MPH. Hmm... that cant be good. Now it will not shift out of first, and on top of that, the transfer case is having issues shifting out of neutral and into 4HI. It grinds like nothing else. I'm guessing the sychros.
I had to be flat towed using a 30ft tow strap :Q Talk about a bad way to do things. It not sits at a buddy's house. I plan on working on it next weekend. Just hoping the tranny isnt fried.
obligatory dead Jeep pic
Update: Had a chance to look at it today. I hosed off the underbody and free up some of the built up mud. The shift linkage on the tranny was covered in grass/mud. Once that was cleaned, it started to shift just fine.
As for the overheating, i flushed the radiator. It was so bad that even opening the drain plug did not drain any coolant. Once i got a rad. flush kit on it, mud blew out of the drain and all is peachy.
Muahahahaha... It's very rewarding to find easy solutions to possible big problems.
