screw you chevy!!!
geno
25,074
4
How do you hit yourself on a hood? And auto hood opening? So there is no latch? That doesn't seem right. I haven't ever had a car that didn't have a latch.
His Chevy has hood struts / springs, so it holds itself up. Hondas use a prop rod to keep the hood up. He took it for granted and just threw the hood up and popped his head and and *wham*
Numenorean
4,442
That is not an auto opening hood. There still is a latch. If you can't tell the difference in resistance from a hood that uses a prop vs. one that uses struts or springs then you need to be hit in the head with a hood.
PricklyPete
14,582
162
I'm still pissed that my Chevy has no tranny dipstick, wow, they must have saved a whopping $3 per unit with that brilliant idea..
Shit at least you still have an engine oil dipstick. Some companies are forgoing that expensive piece of equipment.
Demon-Xanth
20,551
The reason they're ditching the dipsticks is because the dipsticks behind the wheel rarely use them so they've gone to sensors and idiot lights.
