School Networking Project!!
Tallgeese
5,775
<< If you could tell me how to do this, what OS to use, Hubs, cabling, or anything else, It would be great!!!! >>
If this isn't asking for the answer to be handed to you, then I don't know what is...
Working up a plan ON YOUR OWN (ie. demonstrating some effort) and then asking for folks here to review is a different matter altogether.
**NOTE: Hermann beat me to it, but the answer is still the same.
Tallgeese
5,775
<< Hey I'm NOT asking for the project to be done by you people!!!!!!!!!I need just some Ideas !!!!!
that's all I'm asking for!!!!!I'm NOT going to use everything word for word!!!!
Thou doth protest too much, methinks.
n0cmonkey
42,936
Talking like that proves you are older than me :p
JustinLerner
425
Who would have thought that there would actually be at least two random users replying on the same USERNAME? Pretty funny.
I laughed at a couple of responses, which were obviously leading you down the wrong path probably just for "your own good" (backwardly bogus).
RagMan had an appropriate reply though. For your research, you need to consider all options. For example if the school is integrating home laptops and PC's into their 'school environment', what should you consider for interoperability? What types of OS'es will be integrated and networked? Are VPN's and VLANS optional or possible? What type of access will students and teachers have (other than internet)? Will the school have direct dialup RAS for security or lack thereof?
I would think answering similar questions will provide you with a basis for your research and preliminary outlay of the plan. Of course, this all assumes you paid attention in class and can actually design interconnected networks. If you don't understand much about networking, use the OS and protocol you are familiar with as well as the cabling you understand -- then make sure you either relearn the stuff which you don't understand or find another field that you are more inclined toward. (Computer math is not hard, just tedious, like accounting.)
watts3000
619
Why don't you just look through some 2000 server websites they list case study's like that all the time. I'm also in school and we did almost the same project you are doing. I'm not trying to down you are anything but you most likely did not go to class. Because this is a simple assignment.
Tallgeese
5,775
<< I'm not trying to down you are anything but you most likely did not go to class. >>
Go ahead...DOWN HIM!
BTW: If someone has the audacity to ask this forum to do their homework for them, that person better have the guts (cojones, maturity, whatever) to deal with the reaction such a request will receive.
I can ABSOLUTELY guarantee that NONE of the "Big Guns" of the forum (spidey, Jack, ScottMac, L3Guy, Garion, n0c and many others) got where they are in this field by asking someone else to do their homework.
Learning this stuff takes effort. If you aren't willing to work, then take the grade you deserve and don't waste our time whining about your "innocence"
And with that, I'm casting my vote for this thread to be locked
fivepesos
431
go buy some used 10 base hubs, lots of them for each dorm. daisy chain them together with crossover cables. and then connect the top hub in your chain to a realy long cable running to a central location (make sure the cable is cat5 and excedes 100m because if u dont, the timing will be off).
then once you have all that setup, youll need net connectivity. may i suggest an oc192, it will definitely keep up with your blazing lan. use whatever router and csu setup your telco provider gives you. but then plug the router to a machine running windows 98se with a 10base cable. and make sure you know how to get ICS sharing. but some sacrifices need to be made. only 253 clients can connect at a time. so u gotta setup a time sharing system. its realy not that much of a problem. you can mirror files locally by forcing every user to install a gnutella client (u have such a plethora of local bandwith, u might as well use it).
if someone tells u that u need to be in a switched environment, ignore them. 1500 clients is fine for a shared bandwith environment. FDDI between dorms, hell no, theyre just trying to get u to spend more money. and remember, if someone tells you a basic fiber gbit ethernet switch will work (5 ports for dorms, 1 for main campus router, and any others for server clusters), just laugh at them.
ohh yeah, never use cisco or nortel products. theyre just expensive and your generic networking equipment performs just as well.
Goosemaster
48,775
Yeah , RANDOM fool, make sure you "listen" to FIVEPESOS
Anyways, I have to agree with everyone here...we are here to help, not do do your work for you..I assume you are getting paid?.....pay me and I'll tell you how to do it.....:D
:Q
fivepesos
431
cisco online read
more specifically, read some on basic switched environments read this too
however, first read the basics read
then hopefully youll have a clue, and if u have SPECIFIC questions, then well answer them. thank you come again.
