Originally posted by: fatty4ksu
This happens alot with the 939's mostly.
Moron, it happens with EVERY processor that uses a heat spreader. Yes... the beloved Pentium 4 included.
Well, not EVERY P4. As I mentioned above, the LGA775 versions have a load plate that locks down over the processor and prevents it from being pulled out of the socket by the adhesion of the HSF to the heat spreader. Say what you will about the crappy internals of the Preshotts, but the mechanical aspects of the CPU interface are actually pretty nicely engineered.
The processor still sticks to the heatsink, right? Same problem.
No. Check the link that shows the load plate in action (second picture). It locks down firmly over the processor, so it isn't going anywhere when you pull up.
