You've gotta be pretty desperate to let your piss smell up your house all day to save a little water.
Were talking saving water here. And the planet.
Come on Man
Still gonna smell unless you wash it down. (The urine is just gonna sit in the P-Trap.)
The best way to save on your water bill is to make sure your flappers are making a good seal and your ballcock turns totally off. Both of these eventually wear and stop making a perfect seal. Even a little trickle can add up to a whole lot when it's doing it 24x7.
I was having high water bills and couldn't figure out why, turns out the guest bathroom ballcock was ever so slowly leaking along with the flapper. You really couldn't hear it. Being a guest room I was hardly ever in there. Dropped my bill by some 20 bucks a month.
The newer flappers and ballcocks can be adjusted to however much water you want to use, along with the dual flush ones mentioned.
Heh... ballcock. But seriously... put some food coloring in your tank and you'll be able to see if any of your toilets are running.
For 16%? Are you really that desperate?
Try not shitting. Then you won't need to use the toilet in the first place.
It would also reduce the water flow pressure of the flush. What would really work well is if you were to put the tank up near the ceiling and have a large pipe that runs down to the bowl part, and have a rope to flush it. The water would rush down the pipe and build up pressure due to gravity. Then you could get away with less water per flush. It would look really weird though.![]()
I heard recently that my city is looking into water meters, but only in the next 10 years. It will actually be good for people like me, since right now it's flat rate based on the number of rooms. I pay like 77 bucks per month for water which to me seems excessive.
Toilets used to be made that way and still are in europe. The water is much higher and you just pull a chain and the water rushes down.
in that link, they have a youtube video demo with the shit in the toilet being flash down. hahahahha
