Satalite dish question
In heavy rain or snow the signal is not getting to your dish. I have this problem, and from what I understand there is no way to fix it.
No snow where I live here but I have heard it does happen. I usually only lose signal during very heavy cloud cover and even then it's only for seconds at a time.
Originally posted by: amdwolfman
Is it normal for a satalite dish to lose it's signal when it rains,or snows?.If not what is the fix to this problem?
Are you sure the dish is aimed exactly on-target, and that it isn't partially obstructed by something already, e.g., trees, roof overhang, etc.? We're in the Midwest, so we have a lot of inclement weather, but we only lose DBS signal two or three times in a normal year, usually for only a few minutes during torrential rains (no matter what the cable companies would have you believe). If you're sure the dish is clear and aimed correctly, you might have a flakey cable, or maybe you're in a fringe reception area, e.g., Canada or extreme NE or NW U.S. In that case, you can buy a larger dish to increase signal strength.
Of course!
But only the heaviest rain or snow storms would do it... i have a DTV dish up, all the up here in Canada, and even then, it only happens a couple of times a year in only the worst weather. So if it's happening to you a lot, check the transponders and see what the signals are at... if they'are at 60-70, maybe you can re-aim the dish so you'll get them in the 90s. Whether they're at 60 or 95 won't affect your reception quality in normal weather... but it'll give you a good buffer when the weather is crap.
