I have a second machine with the following hardware:
A8N-SLI (Non Deluxe)
Maxtor Sata 150 80GB 7200 rpm
Basically, the problem is that anything that I download has the potential to get corrupted. When I perform windows updates, many of them fail over and over.
When I download software to install or unzip, the executable will be corrupted, or the zip file will be corrupted.
If I copy data from a CD, the data is fine. I've replaced the hard drive with an identical hard drive and I still have the same problem with downloads.
If I use an IDE hard drive, I don't have the problem anymore.
The problem seems to be only with data that is downloaded onto an SATA hard drive.
I've installed the new nForce drivers off the nvidia site (I downloaded them from a separate computer and burned to a CD).
I also updated the BIOS of the motherboard to the latest version 1.07
None of this has seemed to help. Any ideas?
