Sat TV question
RossMAN
Grand Nagus
Feb 24, 2000
79,090
457
Originally posted by: Wingznut
Originally posted by: Fiveohhh
directv alot better than dish to make it worth the $100 for the install?
DirecTiVo is better than everything. :)
Wingznut is absolutely correct, it is worth every penny.
Do it.
TMPadmin
1,886
I don't know the ins and outs but why can't you buy directly from Direct TV? Because some local place bought franchise right to the area?
nsafreak
7,093
That would be Pegasus. Pegasus has rights in certain areas and DirecTV is under contract not to have any of their installers go out and do install nor can they provide you service at your address if this is the case. If it is the case then Pegasus is the only way you can get DirecTV (they basically use one of DirecTV's satellites & programming) and you will end up paying more for it as well.
Shelly21
4,111
As far as I know, if you have a good line of sight, you should be able to get anything you want. Except for local channels that are spot beamed.
Fiveohhh
3,776
yeah that weems to be it, cost an extra $5 a month for the same stuff, and they don't offer the same specials that dtv does either. what a PITA!:(
