- Nov 18, 2005
- 28,799
- 359
- 126
The web client is vCenter which is not free. It requires the minimum Essentials license. You can still manage with the regular Windows thick client and you do lose a bit of the newer VM features but it's not a deal breaker.
You can also manage with this: https://labs.vmware.com/flings/esxi-embedded-host-client
It's just in fling status but I think that will eventually replace the Windows thick client for single host management. There is no downside to picking Hyper-V, Xen, and vSphere for learning to further your career path. All are major players in the Enterprise world. Hell id try all three if I were you. They are all free in some form or fashion.
I did see that, but as it's sort of a beta product, I was hoping there was still something else.
So I just looked into what features are unavailable if using the Windows client.
SATA controller and hardware settings
SR-IOV
GPU 3D render and memory settings
Tuning latency
vFlash settings
Nested HV
vCPU ref counters
Scheduled HW upgrade
All of those, I guess, are Virtual Hardware v9-11, and you can only view those settings, and cannot edit them in the desktop client.
I am a bit worried about that. Not sure if SR-IOV is available on the second wave of Xeon D-1500 packages, but I am sort of interested in that. But I would definitely be worried about "SATA controller and hardware settings." Is that going to limit my ability to passthrough an HBA controller and, if need be, change things if something has to be changed?
