Santa Cruz Win2k Problems
Mag
This is driving me mad. Until Sunday, Win2k and every piece of hardware worked flawlessly. Unfortunately there was some catastrophic event that destroyed that, and a reinstall was required...
Now, with the exact same drivers (and later), and all of the Win2k updates, for no reason that I can see often when there is hd-reading the mouse stutters, as does the sound card. I really need help with this.
KT7-RAID
Athlon 800
256 megs of RAM
TurtleBeach Santa Cruz
Radeon 8500
Creative Labs PC-DVD
Dual 30gig seagate drives -- RAID 0, UDMA 4
Win2K SP2
300W p/s
Any help would be fantastic, thanks.
install win2k ->> 4-1 drivers -> rest of the drivers for other devices.
try moving the SC around has well.
Did do the former, and I don't see why moving the SC would work since it was in that slot before and worked perfectly before the reinstall. I'll try it anyway, though.
did you use ghost at any point during the install/update? probably should during win2k/any ms os installs. sometimes something breaks .. and can't figure out why😛 btw i use same soundcard +w2k😛
I'm afraid I don't even know what ghost is. 🙂
Santa Cruz rocks, no? I wish I knew what exploded...
norton ghost is a backup utility. simplest way to describe it is a zip utility that zips partitions or discs. keep your os partition clean and small(2-4GB) and you can easily make ghost images that you can revert to if something goes horribly wrong. saves a lot of time if you like to reinstall your os. i'm paranoid so b4 i install sp2 i ghosted. then after it worked i ghosted again. now if i blow up the os i can revert to the image and pretty much be up to speed in a couple min. my w2k + offitce appz image compresses to about 600mb.
and yes santa cruz rocks!
