Sandy Bridge model numbers revealed
to continue the car analogies, nehalem is an engine with the same block and pistons as c2, but with higher flowing intake, better exhaust, and a more aggressive cam. sandybridge really sounds like the same thing but with a better transmission or maybe a blower. and cruddy integrated graphics (maybe like the chevy silverado 'hybrid'). i don't think they're changing the execution core itself that much (though i could be wrong).
is exactly what my friends are telling me.
But because of the higher flowing intake, and better exhaust, they use less gas.
And that is what intel was going after.
Green Peace for the entire world!
At least its not intels worst naming yet.
For example how would anyone guess that the i7-970 is a newer and faster processor than the i7-975 Extreme Edition ?
keeping car analogy... you just pulled a Toyota Landcrusier and pitted it against an Lexus IS F1. you know that right?
XE / EE cpus are always in a league of there own.
You are paying for that unlocked multi. That is why.
Dude ive been following your post and you have so much hate in intel Hexcores.
Its obvious.
Well its not for everyone, they are expensive.
But there are 65W Intel Hexcores coming out which you could overclock to 4ghz on air.
You cant say much about intel's hexcores minus expensive.
But if your looking at intel hexcores, then expensive is a "acceptable" condition.
Its obvious.
Eh what ? I point out that the i7-970 is illogically named, and from that you leap to the conclusion that I hate intel hexcores ?
Core i7-920 = 45nm quadcore with 20x multiplier
Core i7-930 = 45nm quadcore with 21x multiplier
Core i7-940 = 45nm quadcore with 22x multiplier
Core i7-950 = 45nm quadcore with 23x multiplier
Core i7-960 = 45nm quadcore with 24x multiplier
One might then assume that the Core i7-970 would be a 45nm quadcore with a 25x multiplier. Instead its a 32nm hexacore with a 24x multiplier.
That's all I'm saying.
and these are still processors and if i really cared i'd ask what you've got. i'd then need a spec sheet to decode what that means if you told me the model. the way intel goes about their naming it'd be like me telling you what my F-150's equipment is by telling you the order code number. but no dealer advertises that way, they say F-150 V8, 4x4, tow package. but all computer makers give you the model number as if that means anything.
all nehalem and derivatives should have been core3, with sandybridge being core4. i hardly know what i3, i5, and i7 are supposed to mean, and i sorta pay attention to this stuff.
intel's advertising has picked up on this as they refer to the 'intel 2010 core processors.' too bad they didn't hire the same people to pick the model names.
as for amd i would continue using the athlon and phenom names to indicate a difference between the consumeriffic and higher end parts. brand names are expensive to develop (which is why pentium is still with us)
they probably made the decision by committee. In fact, if it's true that the larger the group size the smaller the iq, they might have had the entire company vote on it.
speaking of all those odd multipliers, my asus p6t bios allows me to go up to a 21x multiplier on my i7 920 do. anybody else notice that on theirs?
EDIT: n/m, I'm running at 21x178 now.
the naming scheme was changed because AMD decided they wanted to copy the names.
965 was intels, and so was 1090 believe it or not.
The intel sheet my sponsor allowed me to see so i can pick what i wanted to evaluate showed the original gulftowns as i9's as a 1k number.
If you want to blame the illogical name scheme blame it on AMD.
ASUS bios allows you to just use the turbo on mode as a +1 in your bios.
So instead of seeing turbo enabled, you'll see a +1 when overclocking.
That would seem to make a lot more sense. So the i7-980X would have been the i9-1090 or something like that.
Oh well, guess they'll have to settle for having the best processors if not the best names 😀
yup... when i was helping uncleweb make GT, the original realtemp would even list it as an i9.
In some CPU-Z's it also came up as i9's.
Oh and to the guy who said the E5620 was not a good processor....
Westmere absolutely owns...
feel the power of 32nm Quadcore:
Im sorry i cant find anyone who would complain @ That overclock with those voltages.
And those are with A0's... There on new and better steppings now.
I'm not following your argument at all, and you seem to contradict yourself halfway through when you say "You won't need to do that for the version without graphics".
Perhaps you could clarify ?
Ok sure. Search for the leaked roadmaps, they state 6MB L3, while on the die shots there is physically 8MB. The reason for the difference? The 2MB L3 is used to accelerate the GPU.*
Take out the GPU, and the cache doesn't need to be dedicated for GPU purposes. The result is the usable cache size increases. Connect that to the model numbers, the conclusion is the i3/i5 features GPU while the i7 doesn't.
(*Now I do not believe the 2MB L3 is acting simply as a GPU framebuffer. You can't store much in 2MB)
Yes but before making a several hundred dollar purchase on a product, you would research it (I hope).
Unless you walk into a retailer or go to newegg and just hand over your CC before looking/reading about the product. Which would mean you pretty much deserve whatever you get.
So basically you're saying that the i3 and i5 models actually have 4MB and 8MB of cache respectively, but are listed as 3MB and 6MB because some of it is dedicated to the GPU and thus not usable by the CPU ? And that the i7 having the full 8MB then indicates that it does not have any set aside for GPU use ?
Yes. I would like to emphasize that the chances of being solely being a simple framebuffer is ridiculous. But its something to reduce bandwidth usage to help the GPU.
Of course that's IF the rumors are correct.
Why is it the new CPUs needs brand new socket (1155) and, of course, brand new chipsets, what leads to more dough channeled to Intel deep pockets? Is there any problem with the former socket? (1156) Is there any of you who knows how much it will cost the Core i3 2120? And when it will be available on the shelf?
The short answer to that is "because Intel says so". The long answer is to look at AMD's problem with OEMs still selling large numbers of machines using cheap boards with older 7-generation chipsets instead of the latest-and-greatest 8-generation chipsets because, wouldn't you know it, AMD went out of their way to make their CPUs backwards compatible with lots of AM2+ and AM3 boards.
Intel keeps the entire platform fresh and up-to-date in the OEM market by switching sockets or otherwise creating seemingly-arbitrary incompatibilities between their latest CPUs and the previous generation of chipsets/motherboards. It's bad for consumers who want to make the most out of their motherboard purchases, but it does help buyers of OEM machines get the latest gear at their chosen price point when they go out to buy an entire system. As much as I like AMD, you darn well know that there are plenty of OEM AMD machines out there that do not have 890GX chipsets, even though that chipset was squarely targeted at the low-cost OEM market. The old stuff still works, and it's cheaper when it's surplus.
I hadn't thought about that... this certainly puts intel at a much nicer light.
@DrMrLordX: I agree with taltamir. That is a very unique insight you've shared. I have never looked at it that way. You are right. It is good for enthusiasts, but not so good for the OEM market.
n/m, answered my own question
I will add to this by mentioning that one challenge for any board supplier is recouping their design investment...AMD makes their chips backwards compatible to increase the liklihood of existing AMD owners to upgrade their CPU since the rest of the deprecated system components can be recycled.
This destroy's the market potential for the mobo makers...so what are you going to do? Do you invest tons of R&D into developing a latest-gen AMD chipset board knowing that AMD is just going to release something that enables your customer from last year to avoid being your customer again this year? Or do you just keep on selling that mobo you designed last year in hopes of some day finally selling enough of them to have justified developing it in the first place?
Intel, by virtue of their socket-of-the-year-strategy, is a mobo makers dream. First Intel has massive market share, so your opportunity to sell larger volumes of any mobo you design is 4x higher than the AMD scenario. Second because Intel is doing their part to ensure your mobo's from last year are obsolete to consumers this year you stand higher chances of selling new boards to the same people who just bought one a year or two ago.
It's called the supplier eco-system, and Intel manages their supplier eco-system in a way that ensures plenty of wealth gets spread around every time someone buys a new Intel cpu because the upgrade path is rich with secondary purchase points. AMD manages their supplier eco-system in a way that stands to maximize AMD's revenue but doesn't really throw the supporting supply chain too many bones.
Neither strategy is superior to the other for everyone involved, obviously the consumer benefits with AMD's path but the employees of the supplier eco-system do not.
Eh, I don't think it's all that cut and dried.
Intel MB Maker- you make BoardA BoardB and BoardC and you sell about 1 million of each because of the forced obsolescence
AMD MB Maker- you make BoardA and BoardB, you sell about 2 million board A and 1 million BoardB because people just keep buying more of your old AMD board long after the old Intel board is obsolete
I see the potential advantages of intel's style, but there are clear advantages to AMD's way as well. As a MB maker you don't need to spend as much on development because when you do design a good board it will continue to sell for 2 or even 3 years because it's still usable on new CPUs, while a 2-3 year old intel board is useless and all that development cost needs to be recouped in the first year.
What is the best Intel board? X58. When did it come out? almost two years ago (11/08)! Can we stop the FUD about a new MB every year? It is getting really old.
I know that every X58 board will run every i7 quad processor, period. AMD's compatibility is much more suspect, and you can read the forums every day to hear how disgruntled people whine about how their $80 MB doesn't run the newest processor on the newest manufacturing process. I can see the argument both ways, but most people I know upgrade their CPU and MB together. If you are constantly buying new CPUs to replace your existing, your probably wasting more $$$ than someone who buys less often and also upgrades their MB.
Back to the naming convention...I think the i3/i5/i7 is OK (not great). Intel is trying to establish a branding convention where the customer can know i3 is entry-level, i5 is standard, and i7 is "the best". The model numbers within let you know what the cpu speed and core information is. Most customers don't have a clue about this...if you want to know more about the process/cores/freq/VID/cache you need to do research. You could get a "P4" 1.8 all the way up to a "P4" 3.8, and they were separated by some major re-works of the netburst tech, added SSE abilities, cache enhancements, and so on.
In some ways it does, in some ways it doesn't. Like IDC said, Intel does a better job of managing the supplier ecosystem. Just goes to show that if a company like Intel doesn't try to profit off frequent chipset/platform changes, somebody else will.
I forget who mentioned in on these boards, but someone here said that they went out and looked at AMD OEM boxes and couldn't find 890GX chipsets in there, which was telling (I think they kept finding 765 or 770 chipsets, forget which). And by Jove they were right. I would give credit where credit's due but my memory isn't that good.
Good point. Intel really does even out the profiteering by making sure that anyone that wants to deal with current Intel hardware that's in the channel right now has to follow certain obvious rules by controlling supply and limiting the value of surplus. In AMD's world, it's OEM vs. board manufacturer vs. end user to see who can get a leg up over whom.
I don't know if that amounts to a real advantage or not. In the PC world, even if your design doesn't need to be updated, there will be plenty of pressures for you to want to update. New chipsets with new functions will appear, new process technologies will let you produce boards (either of your old design or a new design) at a lower cost, and so forth and so on.
From a raw business point of view, it behooves most mobo manufacturers to keep designing new boards and then selling those new boards.
Maybe if AMD had only one certified board manufacturer, that mobo maker could just sell an old 7-generation chipset board over and over and make a mint on not having to do anything because their old, good board supported every chip and everyone on the OEM and consumer side was happy. AMD might be miffed at being unable to sell 890GX/FX chipsets but oh well.
However, the reality is that there are plenty of AMD board manufacturers out there. If I'm trying to sell 890GX/FX chip-based boards and can't do so because OEMs are picking up somebody else's 7-gen board from surplus (read: not mine), then I can't sell my new 8-gen board, nor can I just make more of my old 7-gen board and expect to sell it because somebody else is already selling their 7-gen board. If I try to flood the market with more of my old boards to beat out the competition that's already letting OEMs bottom-feed, then I'm compounding the problem by dumping even more cheap product onto the market.
The real problem is that, in some fashion, there has formed a glut of AMD-based boards that will support the vast majority of AMD's CPUs from the last two years, and AMD hasn't provided any clear-cut way to get all that junk out of the channel. This makes it hard to bring new chipsets and new boards based on those new chipsets into the market.
Yeah, but that's Intel's enthusiast platform. They haven't needed to replace that for obvious reasons, nor has the consumer particularly needed them to replace it, either.
First of all, no they won't. i7-860 won't run on an x58 board. But I'm just nit-picking.
You do realize that x58 has seen at most three processors on it, right?
Bloomfield, Gulftown, and Gulftown quads (Xeons only). And the 32nm Xeon quads for x58 are really just cut-down Gulftowns so in reality, x58 has seen two processors.
I can't even begin to count how many oddball CPU variants you can put on an AMD 770 board.
Mark put a Thuban on an $80 770 board (I think) and cranked it up to 4.2 ghz. The BIOS support was there. Any problems people are having with backwards compatability with Thuban lie at the feet of mobo manufacturers with their inability to supply a decent BIOS and/or build the board well enough to handle higher-wattage CPUs. In neither case is this intrinsically AMD's fault. For those that remember the Agena/AM2 fiasco, the transition from AM2+ to AM3 has been smooth in comparison.
This was more about the low-end OEM sector where people are going out to buy entire machines and are finding AMD machines with new(ish) CPUs and old(ish) motherboard chipsets. Many of these buyers wouldn't know better until after realizing that the OEM box they just picked up only supports SATA2 or doesn't have the latest and greatest IGP or what have you (and that's only if they ever noticed that).
The same low-end buyer on the Intel side wasn't shopping in the x58 realm in '08; they were still buying updated, low-end s775 stuff. Now they're seeing H55/H57 with Clarkdale. In a year or so they'll see Sandy Bridge i3 in the same consumer space on LGA1155. In many cases the buyer only knows about the latest CPU model (maybe) or that they just want the latest CPU in general, and if the OEM wants to give that to them and do it the Intel Way(tm), they've got to update the entire platform to present that to them.
x58 is on the boutique high-end in the OEM world which is much lower-volume and which operates by different rules.
...unless the new chipsets entail delivering some truly desirable/necessary features.
And that is the tough sell. What percentage of the market needs/desires Sata 3.0? USB 3.0? DDR3?
Around here I'd venture to say the biggest reason people upgrade their mobo is simply that the CPU they are upgrading to requires a new socket OR they want better overclocking headroom.
(hence all the core-unlocking and over-clocking marketing that goes into selling the latest AMD mobos)
I disagree... only the enthusiast consumer, who builds their own computer from parts, benefits from the AMD path.
The vast majority of consumers BUY a whole system... they benefit from the intel path (where they get up to date, higher quality mobos, instead of obsolete mobos with new CPUs)
