If I were you I would get a tetanus shot before you attempt anything else.Originally posted by: Time2Kill
I have some bad news 🙁
I drained the oil today and cut open the oil filter and there was all sorts of metal shavings and metal chunks through it all. I was finding slivers of metal up 1/8x3/8" big in the oil filter with plenty of small metal shavings. On the end of the oil drain plug was a big gob of silver metal sludge.
When I drained the oil, I used a brand new cleaned out oil pan. After it was done draining, I ran my hand across the bottom of the pan and all I could feel was grit. So something is obviously wrong inside the motor.
I'll try and post some pics of the metal shavings.
Any ideas on what I should do now? I highly doubt the dealer will touch the car because of the heads/cam combo. And a couple of engine guys I showed the shavings to think that it is coming from the Cam and the bearings on the crank and cam.
If you could locate one, it would have well over 25K on the odometer. Plus, we all know how well rental cars are drive, right? 😉Originally posted by: XFILE
goto a car rental place, rent out a '02 Camaro SS and swap engines? 🙂
Originally posted by: Ladies Man
i say but the original stuff back on that baby and ship it off to the dealer...
I didn't touch it 😕
But, even then, I think the service department would notice something "fishy." It's kind of hard to truly put a car engine back into the condition that it once was in. The service department will see some socket marks on the bolts or something like that in order to disqualify the repair.Originally posted by: XCLAN
the only sane reasonable advice here.Originally posted by: Ladies Man
I didn't touch it 😕
I didn't touch it 😕
Originally posted by: SuperSix
Are you sure it's sand? And not the new cam grinding itself to pieces because it wasn't installed/broken in properly?
Did you ever notice the "sand" in the oil before the head/cam swap?
Just a quick update on the problem...
Coolant found its way into the oil. I'm not exactly sure how it got in there, the head gaskets didn't show any signs of failure/leaks. All the tops of the pistons are fried and flaking. That is where most of the metal chunks are coming from. Piston skirts are marked up and worn, piston rings have all sorts of crud in them. All the bearings through out the motor are gone. Most of them show signs of heavy wear and burn marks.
Havn't been able to check out cam/crank yet (can't get crank pulley off), but the lifters looked fine. Cylinder walls looked fine to the naked eye, but I'm taking the block in to be checked out. Also, the screen on the oil pump had all sorts of gasket material plugged up in it and the bottom of the oil pan had some nice chunks of metal in it along with all sorts of fine metal shavings.
