- Oct 22, 2015
- 121
- 13
- 81
I have a Samsung SSD 980 Pro that is showing some errors in both HD Sentinel and Samsung Magician. SMART health status is 87%. When I run a full diagnostic scan from Samsung Magician, it runs about 15 minutes then gives me this error:
"Recovery failed. Check the disk connection and perform a Diagnostic Scan again."
It shows 5 blocks as red (bad) instead of blue (good) in the scan results.
After the scan, it says "Magician has found an error on this drive, it is recommended to recover."
I click Recovery, It at first says recovery in process, then after only a couple of seconds, it says: "Recovery failed. Check the disk connection and perform a Diagnostic Scan again."
It also says:
"Diagnostic Scan has stopped to to unknown error."
Seems like last time I ran it, there were more than 5 bad blocks. Do I need to just keep running this over and over until all the bad blocks are gone? Does this software actually reroute bad blocks or do I need some other software for that? HD Sentinel seems more of a diagnostic utility than a repair utility... right?
What are my options? Normally, I would use a USB to M.2 adapter and clone a failing drive and then swap them out. Macrium Reflect clone of this drive fails because it doesn't like the errors.
It also says:
