BonzaiDuck
- Jun 30, 2004
- 15,877
- 1,548
- 126
Just to add an epilogue to this . . .
I'd begun to assume -- many months ago -- that Primo was "storage-mode agnostic." After I made the assertion again a few days ago, I wanted to double-check, because I really hadn't tested the proposition first-hand myself. There were forum posts at ROMEX in which posters had set up Primo for a RAID0 array, but were now wondering whether Primo implements TRIM. They seemed to be confused or oblivious to the fact that, if the BIOS version didn't support TRIM, neither would Windows -- nor would Primo. Romex is explicit: it allows TRIM to work, where it CAN work.
Meanwhile, I just decided to put a direct query to Eric Chen at Romex tech-support to confirm the "agnostic" feature, and here's the answer:
PrimoCache doesn't require a particular BIOS storage mode. It is based on Window volumes whose underlying disks can be in IDE, AHCI, RAID or other modes.
Please feel free to contact us whenever necessary.
Thank you.
Best Regards.
Eric Chen
So that settles it, and I'm willing to bet Z15CAM can at least see it working properly, even if he chooses -- in the end -- to abjure adding it permanently to his configuration.
Thank you.
Best Regards.
Eric Chen
