Hello,
I bought a Samsung NP700g7c with GTX675m yesterday. However, after playing borderlands 2 for 10 minutes my GPU temperature climbed to 90 celcius degrees, CPU temp was around 70 celcius degrees. This got me very concerned about whether I should return the laptop or not. It also considerably heats up the WASD buttons which makes it hard to play games for longer periods.
I figure some of you used this laptop longer than me, so did you ever saw similar issues?
If this is something normal, then I guess I'll use external keyboard and monitor to use this laptop =/
I also wanted to ask this to crisium as his signature contains this laptop spec, however I couldn't PM him as I don't have 10 forum posts.
