Samsung Monitor Question
Sahrin
90
I've heard that Samsung monitors are very well-made, and I was looking to pick up a 997DF, but it's very very low price point (179 for a 19" new) made me a little suspicious. Is this a monitor to be on the watch for, or is it a steal at that price? What do the suffix letters "DF" and "MB" stand for? Thanks for your help.
konakona
6,285
while it doesnt directly answer your question, the best samsung 19'' is 909NF, just so you know :)
duragezic
11,234
4
The DF stands for Dyna-flat, which is their name for their invar shadow mask they use. I haven't followed the change of Samsung monitors since I got my 900NF (the bomb) a long time back, but I'm guessing the 997DF is just an updated model of the 955DF. The 955DF is/was a great monitor for it's price... it's always recommended a lot, in Anand's Guides too, so I don't think you could go wrong with one. Just compare the specs, perhaps the 997DF just has better refresh rates than the 957DF. I would be certain the monitor you are getting is capable of running @ 85hz for the resolution you intend to use.
Ardan
621
The 997DF DOES have much better refresh rates than the 955DF. On the 997DF, you can run 1600x1200 @ 75Hz easily. It isn't expensive either, because Best Buy has it for $199.99 with a $20 rebate. I saw it there, running their demo and it looked excellent.
If you were to choose between the two, choose the newer 997DF. It also had a TCO '03 Sticker on it! :shocked:
I don't know about MagicBright so much. I know the 957MB is highly thought of by PC World and others, but I saw the 17" version next to the 997DF and I really couldn't see what the difference was. I would like to point out that the 900NF is no longer available, and hasn't been for some time.
