Samsung Galaxy Note Pro 12.2
Zaap
7,162
424
Don't understand the draw (heheh) of this over the Surface Pro 2.
For me it was the size and the screen. The size is a major plus for productivity for me. Also because it's so thin it doesn't feel as bulky and heavy as the Surface.
I messed with the two side by side when I bought it and in just about every aspect that matters to me specifically, the Note Pro was the better of the two.
zerogear
5,611
9
There are a lot of people who want Microsoft to make a 12" or 13" Surface Pro as well.
you2
7,076
2,124
If MS made a 12 inch surface pro that weighed around 1.5lbs and had 9 to 10 hours of battery life I would have considered it esp if it was in the 750-800 range. The key points are
12-13 inch
9-11 hours of solid use battery life
1.5ish lb
if you make it much more expensive than 750-800 or heavier than 2.5lb then there are some good options in the ultra book arena.
Naturally if it has sucky battery life that's a killer before we get started (don't understand those ultra books with 6-7 hour battery life).
Bateluer
27,730
8
They have x86 i7 CPUs with 8GBs of DDR3 RAM, with HD4600/5xx0 GPUs, with 256GB SSDs, and 13.3in FHD or higher resolutions. 6 or 7 hours of near full performance on battery is pretty damn good. Not like you're going to be working for 7 hours straight on it without access to power anyway.
you2
7,076
2,124
Well I care about web surfing and video; so video run down test is what I mostly use. Most of them have hd4400; but the macpro does have very good battery life and hd5000 - but also is more than 100% heavier.
hajime_android
I'm waiting for a keyboard dock that will transform this into a 12" laptop.
Could you please let us know the name of the nice stand you are using? Is there a link? Thanks.
Zaap
7,162
424
Sorry, hadn't seen this.
Stand is an iHome iStand. http://www.amazon.com/iStand-Adjusta...dp/B00BEJVYAG/
It's perfect for larger tablets like the Note 12.2, with a very good range of adjustability. My only issue with it, is it's a little bulky when folded. I currently just use this traveling:
http://www.amazon.com/Flexible-Alumi.../dp/B00BXXP1Z2
It's not very adjustable, but holds the 2.2 sturdy and at a decent angle, and best of all for travel, it folds to virtually nothing.
