Question Samsung 860 EVO 38c (100F) Temperature okay?
EpicSurvivor
1,044
48
So I just noticed my Samsung 860 EVO 1TB is running at 38c or 100F I was wondering if this was normal and if other users with similar drive can share their temps. That's the main OS drive, the secondary storage 860 EVO 1TB drive is running at 33c or 91F which is 5 degrees cooler.
EDIT: C is OS Drive F is the Storage drive.
Appreciate any input I can get.
Thanks
UsandThem
16,068
7,383
Get the temperatures from Samsung Magician app to make sure they are being read correctly.
My 850 EVO in my laptop is usually between 28C - 34C. Slightly higher temps on the newer 860 EVO wouldn't be surprising (or something to worry about).
UsandThem
16,068
7,383
Do you have one of them installed behind the motherboard (like is common with many cases anymore)?
If so, that would explain the temperature difference between the two as not much airflow gets back in that area.
EpicSurvivor
1,044
48
No but very interesting you mention that I had no idea you could mount 2 SSD's on the back like that lol really cool! This case has the option to add HDD bay at the front bottom of the case as a matter of fact one of my front 140mm Intake fans is blowing air directly at it as you can kinda see on the picture.
I honestly have 1 explanation why one Drive might be warmer than the other. I think the drive is warmer because its the main OS/Boot drive and is constantly under use. That one was bought new November 2019 the other one that is cooler I just got today in the mail from Newegg. Just an idea. Oh and both SSD's are practically next to each other maybe you can see it on the picture.
UsandThem
16,068
7,383
Yeah, if your OS drive is writing/reading a lot of data, it will run warmer.
Not to mention, the drives on top of each other like that, would likely cause one of them to be a little warmer since heat rises.
But your temps aren't anywhere high enough to worry about it.
EpicSurvivor
1,044
48
Okay fair enough appreciate the help. Gonna rest easy for now.
Reactions: UsandThem
