s it possible to connect 2 modems and run from 1 os ? thanks again ;-)
camshi
i have duel boot winme 4 games and win2k pro 4 work.
i live in scotland and can only get modem access at the moment ;-(
i have 2 phone lines and would like to install another modem in my box and d/l constantly with 1 and surf with the other.
i would be running 2 diamond supraexpress 56i modem`s
is this possible ?
i would hope so ....
cheers 2 all ....
camshi
win98 and I'm assuming they kept it in winME has shotgun. It allows you to combine two modems together. But there are some catches. You have to have an ISP that will allow two simultaneous connections. Those few ISPs in the US that allow this also charge an hourly fee when you are logged onto both modems.
In essence, the first modem logs in like normal. When the modem determines you need more bandwidth, the second modem will then dial out. This modem will drop connection when its bandwidth hasn't been used for a certain amount of time.
I have never set this type of connection up since my ISPs never allowed it and I couldn't do this with two separate ISPs. Look up shotgunning in MS's Knowledge Base.
DOn't worry, WIndows doesn't dial the second modem only when you need bandwidth. It dials the first modema and connects, and right after the first one connects, the second one dials and connects. To do this, simply install your second modem in your computer and create a dial up connection to make sure that it all works good with the second modem alone. After that, delete the connection you made to test the second modem and go into the properties for you main dial-up connection (in dial up networking) and then click the "multilink" tab up at the top, and add your other modem. You are done. Now, You can't just use one to download and one to surf with. Windows will combine the bandwidth of the modems. Try it and you will be addicted to it, lol. Before I could get DSL I had this set up with 3 phone lines and I got almost as good upload speeds then As I do now. But not near the download speed though, lol, I have 1.5 meg per second and it usually runs at about 2 meg per second.
Have you heard of Starband?? It is 2 way satalite internet access WIll dsl speeds. There is also diretpc but they use a phone line for all your outgoing data. I just downloads from the satalite at around 500k + per second.
After you get those modems hooked up, email me and I'll give you some tips on tuning them to get some killer speeds. You will get faster speeds in 2kpro probably as It is set up for tcp/ip a little better than ME.
Hope this helps
thanks
mike
mlhser@bellsouth.net
thankyou and yes this has helped so much ;-)
so i doesn`t depend on my isp ( which gives me free unlimited free dial-up ) ie: i can use my login account as many times as i like to connect via modem with my user/pass.
so i just need 1 dial-up account and it will give me 10k/sec.
nice 1 ;-)
nice 1 ;-)
BUT before i go out and buy another modem IS this going to work for sure ?
thanks
ON the hardware side, 99.9% sure. It all depends on that dial up. It has never failed for me. And yes, you can get up to 10-15k with dual modem, you will just need to tweak it up right. Off the bat you will get (my opinion) at least 8k.
Let me know how it works and if you have any questions feel free to ask me.
thank you
mike
Yes it does depend upon ISP. All of my ISPs to date have had unlimited plans but only one has allowed multiple logins by the same user. If they didn't limit this in some way, there is no reason for someone to not get an account and share it with as many people as they like. Find out this info first before you a dead set upon the second modem. Its a great idea if the software on their end will allow it.
Also consider getting one of the dual diamond modems that have both modem connections built in. It will save you an ISA slot.
