S@H daily team stats 06/10
OhioDude
4,223
RossMAN --
To get the most out of your system, I would suggest running the command line version of the Seti client as opposed to the GUI version. Look for i386-winnt-cmdline.exe about halfway down this page:
http://setiathome.ssl.berkeley.edu/unix.html
I have a PIII 700 (100MHz FSB) that takes about 8 to 8.5 hours to process a wu with the CLI client. That's running WIn2k Server which seems to process a bit faster than the CLI on Win9x OSes. We had a PIII 866 server in here with 512MB Rambus and it did pretty good with Seti, around 7 or 8 hours per wu, if I remember correctly.
Assimilator1
24,165
524
Rossman
Your rig should do good times of around 6.5hrs (with CLi v3.03) thanks to the 133MHz FSB & CAS2 RAM:).
1 variable though ,what chipset does it use?
Smoke
Distributed Computing Elite Member
Jan 3, 2001
12,650
207
RossMAN,
Are you referring to "joining Seti Team AnandTech" or "setting up your SetiDriver and CLI"?
Smoke
Jan 3, 2001
12,650
207
I noticed another new member, db, that had trouble joining yesterday is now showing up as a member of Team Anantech. I couldn't find RossMAN.
