TheELF
This isn't showing gaming performance though,it's showing rendering performance through a game engine,not the same thing at all.After this, who ever says Ryzen Gaming performance is a fail is Trolling.
I don't think that the price slide is over by a long shot as it just isn't holding up to the Intel offerings the way people were led to believe it would. I should write a book called "When Fanboys Attack" over how people who point out anything that is not in AMD's favor get railed against.R7-1700 now on eBay for $279.99 🙂
https://slickdeals.net/f/9845604-am...ebay-bucks-no-tax-for-most?v=1&src=SiteSearch
R7 1800X 4C 8T @ 4GHz vs Core i7 7700K 4C 8T @ 4GHz
http://www.zolkorn.com/reviews/amd-...re-i7-7700k-mhz-by-mhz-core-by-core/view-all/
With GTX 1080
Then you do not understand the context. Nobody here are resisting the numbers.
People are trying to understand what is the REASON for this. Some say its because it has Sandy Bridge IPC. It is rubbish. This is the thing that I resist. Spreading FUD, and misinformation over forums. The IPC is on Haswell/Broadwell level. For example here: Kraken is single threaded benchmark.
http://www.guru3d.com/articles-pages/amd-ryzen-7-1700x-review,10.html
90% of professional workloads are showing this. What happens in gaming then? How come more complicated and more demanding workload for CPU is showing that Ryzen is on par with latest Intel offerings, and in Gaming - behind it?
Let me put things into perspective for you.
Ryzen is not able to push high framerates in low level settings, and medium sized resolution, while maintaining around 20-30% load on the CPU.
Ryzen is not able to push high framerates in high level settings, and medium sized resolution, while maintaining around 30-40% of load on the CPU.
Nothing red is starting to light for you, in your mind, by looking at this?
Err... I'm as pro AMD as anyone but you proved your point by underclocking the 7700k and maxing out the OC on the 1800x? What does that prove again?
Little more testing in crysis3.Crysis3 can use all 16cores on ryzen.
r7 1700 4015Mhz
https://www.youtube.com/watch?v=zGS41CVIoUU
And 6700k 4.5ghz HT on
https://www.youtube.com/watch?v=mChLjbIWzMk&feature=youtu.be
HT off
https://www.youtube.com/watch?v=Dx_fMmgmFok&feature=youtu.be
Wait, so just you said I was stupid if I didn't know the real world value, and when called out, you now say it is not "particularly relevant".Did they assume that though? This sounds like a strawman argument to me. But if some testers did make this claim they're jumping to conclusions.
As you should well know; low resolution benchmarks are an attempt to remove the GPU from the equation as much as possible, thus making it ~more~ a CPU vs CPU test. I never said it was particularly relevant. Just like synthetic memory bandwidth tests may not be particularly relevant to real world applications.
All I said was that to completely discount these tests because you, or someone else, doesn't understand the scope of the information provided is stupid.
That's why the 6900k wins in new games, right?Testing at 720p is just an easy way to not have a gpu bottleneck.
If you pick a cpu purely for gaming the 7700K is faster, even if you're usually gpu limited, the 7700K will finish the cpu part of calculating a frame more quickly, giving you slightly lower latency.
That said I think ryzen is not a "fail" for gamers, comparing overclock/overclock intel is only 30% faster in games like arma 3, where before ryzen intel was almost twice as fast.
It proves that games need to become more multi-threaded and AMD needs to work on Zens clocks for future processors.
Heck we may even see R5s or R3s clocking higher. You never now.
Also, the premise that we will be getting very decent and cheap 4c/8t cpus, that will actually be running almost like 4Ghz Kabylakes, should be celebrated by all.
Intersting results of the 4C/8T Ryzen CPU made from 8C/16T 😀. Makes me think of what will be APU capable of.
if they remove the l3 like on previous APUs it's not going to look like that
720p is a meaningless drawcall benchmark that doesn't tell you anything about REAL gaming. It's no different than using cinebench to predict gaming performance. Actually, cinebench is probably far more accurate nowadays..
Now, we are back to stupid again? Wouldn't that make you stupid, since you cannot name one fringe case in which it's relevant?
and what on your mind is showing "gaming perfomarce" ? cause in earth-1 before barry screws the timeline rendering via an engine IS gaming perfomanceThis isn't showing gaming performance though,it's showing rendering performance through a game engine,not the same thing at all.
Nope I said it was stupid to completely discount low resolution benchmarks. You've obviously confused these results in the past so I decided to correct you.
I didn't state any case where these benchmarks were relevant or irrelevant; again I said it was stupid to discount these values as meaningless. Just because you, or other people, don't understand the scope of this information doesn't mean it's useless.
Because you freaking cannot state a case... You don't have one. It doesn't exist!
And that's not even getting into the fact of how it is misrepresented. It's a benchmark of the limitations of the game engine and drawcalls.
It's become a tradition at this point, and no one bothers to question if it still, or ever for that matter, makes sense.
I am done.... You people can continue to believe in Santa if you want to. I mean, you could be right. Maybe his factory is just invisible?!
So, I was right. You moved the goal post, and the crux of your argument is "Santa's shop is invisible!".You've obviously never heard the "absence of evidence is not evidence of absence" idea.
I will post it again and again. It's stupid to say that low resolution benchmarks have no value. I will not comment on how much value they may have, nor in which situations.
I will simply say the value of these measurements is non-zero, as anyone with a scientific mind will appreciate. I will keep on saying this no many how many times you keep trying to distort the subject.
It is only part of the gaming performance,the game responding to your actions is just as important and is not being shown by just rendering.and what on your mind is showing "gaming perfomarce" ? cause in earth-1 before barry screws the timeline rendering via an engine IS gaming perfomance
You know why low res tests are interesting?So, I was right. You moved the goal post, and the crux of your argument is "Santa's shop is invisible!".
Yes, I am aware of that phrase, as I hear it often from religious philosophers. Which is why I find it ofd that the next line you use includes "scientific mind".
A person with a scientific mind wouldn't make arguments for the existence of something with absolutely no evidence. I have repeatedly asked for evidence, and your rebuttal is "have faith". Very scientific.
