A year ago I played with some two chiplet 3000 series CPUs and I noticed, that one chiplet tends to clock (boost) slower.
Now I already tested two 5900X and one 5950X. All three CPUs confidently reached advertised boost clocks. Both 5900X had the second chiplet approx 100 MHz slower than the first one.
Here is a screenshot of the second 5900X:
It can hit the advertised boost clock and more on ALL its cores, which is in my opinion impressive.
When I got the 5950X, I expected the second chiplet to be weaker as well. To my surprise it is cca 200 - 250 MHz slower. I did not expect such big difference. The first chiplet is hitting 5 GHz on almost all its cores. It looks very nice.
Following are two different monitoring runs of the 5950X:
I noticed, that one review sample had two chiplets capable of hitting 5GHz:
So I arrived to these questions:
How much slower is the second chiplet on your 5900/5950X?
Is it possible that there are some "lucky CPUs" getting both very fast chiplets and some less lucky getting just one?
Is it possible that if a CPU gets some excellent first chiplet which alone can fulfil some defined performance goal, it gets slow brother, and having one markedly slower chiplet is not bad luck but it simply means that the first one is exceptionally good?
Would there be some demand for "5950XX" comprising of TWO highest binned chiplets? How much extra would you pay for such a CPU?
