- Mar 31, 2001
- 13,749
- 6
- 81
Here's the scenario:
Say you were 200 lbs. You started to run to lose weight. Time passes, you're now 175lbs. Running got easier as a result of a lighter body(and increased strength/endurance). You obviously don't lose as much weight as you used to despite running faster and longer. So you change things up and begin to run strapped with a backpack filled with books/whatever to replace the 25lbs lost to weigh you down again. Is this a good idea?
