In another thread, someone said to test P4 hyperthreading I should run two instances of Prime95 at the same time. How do I do this?
The other thread said to enter "Prime95 -a" using the command line.
I figured out how to get to the command line (typing cmd into the run field) but that takes me to c:\Documents and Settings\My Name.
Do I enter "Prime95 -a" here? It doesn't work. Do I need to change the directory first?
Can anyone give me some step by step directions?
Also, do I do this dual test as a regular Prime95 test or a torture test? If a torture test, what settings do you recommend?
Thanks
Thanks
