running cable wires upstairs
I hope this is the right spot for it :X
So after i got the linksys firmware working upstiars (fantastic by the way) I want to get cable upstairs in my room. only 4 channels hurts and when you cant watch espn/discovery/history in my room it kinda hurts..so i got thinking how to get cable up in my room.
the cable box is downstairs in the family room, basiclly a long way away from me. I was thinking running the wire down the vent to the basement, but then i would need to find a heatshielded cable.
questions: would running the wire through the vent be the eaisest way?
are heatshielded cables expensive? heat winter air condic summer.
thanks for the help 😀
i wouldnt use a fancy "heatshielded cable
maybe if its running into the heater lol
dont worry heat only maybe gets up to 120 degrees at most
