Originally posted by: CTrain
All it is is a bunch of patterns.
I thought my method was decent but some of these new methods are just way better.
My Method consists of:
** There are a series of patterns that you use that only affects certain part of the cube and all the other parts remain intact.
With that said.
A) Solve 1 color first.
b) Then solve the first top layer linked to the color you just solved.
c) Then solve the middle layer.
d) Then get the 4 corner in the right place(the corners might not face the right way but just right position)
e) The get the 4 corners facing the right way.
f) get the 4 middle pieces in the last layer and you have a SOLVED CUBE.
Originally posted by: coopa
How long did it take you guys to start being able to solve in under a minute?
How long did it take for you to figure out how to solve it at all?
Where did you start learning how?
Could say, 3 hours of work on it (using a guide of some sort) and maybe 2 hours of practice a week make someone a good/ok rubik's cuber?
I have had a few in my room that I occassioanlly rotate around, and I have NEVER solved one. any tips?
