supremeninja
Hey all,
I am looking for a cost effective router to vertically mount inside an outdoor LED display (digital sign).
It will be installed inside the steel sign, so weather is not a problem... however, heat is.
It will be wired into a controller in the sign, and connected through WIFI to update content of the sign. This will be used at max, once a week... and usually only 1 or 2 times a month. The files transferred is less than 500MB, so speed is NOT an issue.
What I'm concerned about most is:
1. No dropped WIFI, and no need to reboot. I want to make sure I don't go up to the sign, open it up, hardwire, and reset the settings.
2. I need to make sure if the power is off for 24 hours, all the settings (security, IP) are still set up.
3. No problem with installing vertically
4. Range - Although not as important, the further the range, the better.
Right now, I'm looking at Linksys WRT54GL because it's the most solid router I've used and newegg agrees. I've had problems with D-LINK.
Any advice is always appreciated 🙄
