kornphlake
- Dec 30, 2003
- 1,567
- 9
- 81
All those specs actually come from somewhere and are based on the engineering judgment and testing that OEM has.
I used to be a design engineer at a major jet engine manufacture. My company spent millions testing different oils, lubricants, etc. And testing proper servicing intervals and procedures. We also had material programs to bring new very specialized materials into existence, a new alloy program cost in the tens of millions. But a ton of our customers think they know better and use different oils and lubes and buy aftermarket parts made with inferior alloys.
The manual is generic because it does not need to change much model to model and testing is very expensive, especially if it gives you the same results you already had.
^this
It's not unheard of in heavy industrial equipment to use whatever lubricants or parts a salesperson recommends. We had a bearing vendor recommend we switch from a PFTE based grease that is required by the process to a hydrocarbon grease. Duh, a hydrocarbon grease will be better, but it would potentially contaminate the product that piece of equipment worked on. The recommendation was completely inappropriate, however the dept. manager who forwarded the report on was ready to place an order for hydrocarbon grease that day.
Occasionally you'll run across an OEM spec that calls out a cheap grade of lubricant as a cost saving measure, or when a parent or sister company manufactures the lube, but most often heavy industrial, including automotive, lube specs are not chosen on a whim.
