Originally posted by: Ornery
Pentium 4 Dell Models that do not require a power supply adapter:Originally posted by: CorporateRecreation
Too bad he can't upgrade his PS since the 8200 uses the special dell-only molex connector.
Edit: his PS is probably around 300 since Dell rates theirs at the mean instead of the high.Do you clowns ever contribute any information that's actually useful?
- Dell Dimension 4300, 4400, 8200
Um actually I own a Dell 8200 with the special connector on it, I can take pictures of it if you so desire.
Thanks for pretending to know what you're talking about though, and making an ass out of yourself
It's not the extra connection you linked, it's actually wired to look EXACTLY like a standard ATX supply but it's wired differently, I can provide the correct pinout here if you wish:
Dell:
Color
Signal
Pin
Pin
Signal
Color
Gray
PS_On
11
+5v
Red
Black
Gnd
12
Gnd
Black
Black
Gnd
13
+5v
Red
Black
Gnd
14
4
Gnd
Black
White
?5v
15
Power_Good
Orange
Red
+5v
16
+5VSB (Standby)
Purple
Red
+5v
17
7
+12v
Yellow
Red
+5v
18
8
?12v
Blue
KEY (blank)
19
9
Gnd
Black
Red
+5v
20
10
Gnd
Black
ATX:
Color
Signal
Pin
Pin
Signal
Color
Orange*
+3.3V
11
+3.3V
Orange
Blue
?12V
12
+3.3V
Orange
Black
GND
13
GND
Black
Green
PS_On
14
4
+5V
Red
Black
GND
15
GND
Black
Black
GND
16
+5V
Red
Black
GND
17
7
GND
Black
White
?5V
18
8
Power_Good
Gray
Red
+5V
19
9
+5VSB (Standby)
Purple
Red
+5V
20
10
+12V
Yellow
"An even bigger crime than simply using nonstandard power connectors is that only the pinout is nonstandard; the connectors look like and are keyed the same as is dictated by true ATX. Therefore, nothing prevents you from plugging the Dell nonstandard power supply into a new industry-standard ATX motherboard you installed in your Dell case as an upgrade, or even plugging a new upgraded industry-standard ATX power supply into your existing Dell motherboard. But mixing either a new ATX board with the Dell supply or a new ATX supply with the existing Dell board is a recipe for silicon toast. How do you like your fried chips: medium or well-done?"
Originally posted by: mobobuff
Tell the knob to get a damn 400W PSU, they're only 50 bucks.
Originally posted by: toant103
so if i plug a normal ATX PS in the dell 8200, it would fit but it won't work?
Haha, it would fry the fvck out of your board.
In defense of ornery, it seems the internet has conflicting opinions about the 8200. I think maybe there are different versions because the one I have definetly is non-standard and according to dell tier 3 support my model has the special dell one.
Perhaps there are different versions?
To the OP, get a voltmeter and test yourself, should take you 2 minutes max. Look at the pinout above.
yeah, for a POS
my ass
that's $60 buddy.
you can't get a good 400W psu for 50 bucks...
Sorry Drew, I thought you were just being another Dell bashing bonehead. However, I'm not finding any controversial info about that power supply:
Dell Power Supply Selector
The optimal choice for your Dimension 8200
Check the SpecsDell's 250 watt power supply has been debated over and over.
- Compatibility: ATX (Rev. 2.03)
M/B Connectors: 20-pin, P4
See diagramUpgrading Dell 8200 Power supply
- Most standard ATX power supplies will NOT fit into a 8200 without modifications. An ATX power supply has an ON/OFF switch and an 8200 does not. To use an ATX power supply, one would need to make modifications to the case. In some cases it was found that the power cord was also on the wrong side. For those who would like to cut a hole in the back of their case for the ON/OFF switch, a standard ATX power supply will work with no adapter or converter. Your computer will work fine.
Point is moot anyway, if the OP isn't going to touch it, and I wouldn't either.
- Am upgrading my power supply in my dell Dimension 8200 so that i can upgrade my video card. It currently has 250W power supply. in discussing and e-mailing Dell, i was told that dell only went up to 250W on this model, and has nothing larger that they sell. However, they said that it was not a proprietary power supply, and i could buy one from another manufacturer.
