Need4Speed
id be crazy to change my oil every 3k since i put on almost 3000 miles a month, hell i dgo poor 😛 ... i generall stretch it to 5-6k and use synthetic
Originally posted by: edro13
My mom's new 2003 Accord came with synthetic in it and the manual says to change the oil every 10,000 miles!!!!! I was floored!
Roger in your opinion how would you rank the following oil in terms of quality?
Castrol
Penzoil
Valvoline
Havoline
and whatever else I forgot.
TIA
Ausm
guess they make some really tight engines, that can handle it, and dont get much in the way of contaminants.
Mine came w/synthetic oil and they told me they changed it before I got it (it has 4,500 miles on it, but it's still 'new'). The sticker says to change it at 7,500 miles (the one they put on there). I just got a letter saying that I should be at around 6000 miles now and should schedule an appointment to get it changed by them. The book says to change the oil when the Change Oil light comes on (it detects when the oil is bad, somehow). I have about 5,900 miles on it now and will probably change it around 6,500 to 7,000 just as a first change thing.
No, it is set to come on at designated intervals....nothing to do with fluid analysis...
It does not "detect" if the oil is bad, the odometer trips the light at a preset mileage.
As long as you're here 😉 ,where does Quaker State rank in terms of oil quality? Specifically, their syntethic blends.Originally posted by: Roger
One word,..................Employees 😉
My Grand Prix supposedly monitors engine conditions, mileage, etc., and displays the oil life as a percentage on the DIC. I don't really go by it though.Originally posted by: vi_edit
I thought BMW had a system that actually monitored the oil cleanliness and would prompt you when it needed to be changed. And it would do that as various milages based upon driving conditions and driving styles. Not based upon a preset milage.
Mercedes has this system and it only works with synthetic oil.Originally posted by: vi_edit
If you are having labor issues I know a wise.. Ex-Ford mechanic that could use a change of pace. 😉Originally posted by: Roger
One word,..................Screw it !!!😉
Edited for a more wise a$$ remark.
Castrol
Penzoil
Valvoline
Havoline
TIA
Ausm
Order of quality ;
Castrol
Valvoline
Pennzoil
Havoline, Mobil (petroleum based), coastal are crap, I used to work for Mobil, the oil I pumped into my customers vehicles sucked a$$, unfortunately because I was running a Mobil repair station, I had no choice in the matter.
These oils have the absolute minimum additives required to pass the A.S.E. service requirments, that's why you can find these oils for ninety nine cents a quart.
"Tightness" of the engine as you call it (Close tolerance engines) has nothing to do with it, it is the ability of the oil filter, air filter and PCV valve that determines the amount of dirt entering the engine.
Now mind you, certain manufactures raise thier oil change intervals because of the quality and design of thier materials they manufacture the engines out of.
hrmm.. really? what about their synthetics (mobil)? and where can you find them for 99c a quart
They are up there as long as you purchase full synthetic, "synthetic blends" give you no advantage what so ever, The reason Synthetic is superior to Petroleum based oils is because they contain long chain molecules which resist breakdown and they do not contain any waxes and other non-essential crap which is inherently found in petroleum based oils.
"Synthetic blends" are nothing more than Synthetic oil mixed with petroleum based oil, what is the sense of buying something like that ?
