- Nov 20, 2011
- 5,647
- 47
- 91
Looks like he will be the third place winner.
PTF release note v2.01 repairs the following issue.
A race condition would initiate a bad pointer reference which would overwrite the canned phrases in memory used by the NLP engine.
Since no canned phrases are found in memory the reply NLP function would run into a failsafe loop and repeat the last phase found in the temporary response stack register. A soft IPL is required to correct the problem.
PTF requires a replacement of the High level logic board(A1) with a new version that contains an intel Skylake processor in order to leverage the SGX feature.
SGX feature will be used to create a protected memory enclave so critical memory regions would not be overwritten in the event of bad pointer references even if they are initiated by a ring 0 function.
FPGA interpreter board(L4) 1.03 VHDL enhancements. (changes in logic to improve response rates by 8%)
