RJ-11 to RJ-45 ethernet cable wiring stardard
snake253
67
My son is moving to a dorm where you need such a cable to hookup to the school network. Does anyone know what is the wiring standard to hookup the RJ-11 side of the ethernet cable ? I need to know which wiring should be connected to which pin.
spidey07
65,469
It depends on the standard.
Generally there is no RJ-11 to RJ-45 "standard". Otherwise it would no longer be a standard. That's like saying what is the standard for standardized apples to standardized oranges?
RJ-11 is not a standard for ethernet. It will work, but I want to strangle the people that did this. Makes me thing you aren't really getting ethernet in the room.
And before anybody pounces - sure the RJ-11 pinout was later included into RJ-45 connector, but that is a hole-nutter thread.
JackMDS
29,546
422
snake253 post what needs to be connected to what, RJ-11 is usually telephone jack and thus has nothing to do with regular Ethernet Network.
robmurphy
376
Are you sure that a cable is needed and not an ADSL modem. Sounds more like there is an ADSL connection in the dorm.
Rob.
snake253
67
Yes, it is just a cable. The information for the school says some dorms will require this special cable. I was able to find this cable using a google search, but unfortunately there was no information on the pinout.
