After going through the and altering the code to the .cfg file, I finally have Rivatuner recognizing my gts(g92). I've gone through and made the fan profiles by following the guides on guru3d. It's great! I love that I can have my fan set at stock and will kick up as needed instead of having a to listen to the fan at 60% when its not needed yet.
But when it comes to overclocking the card itself, I'm a bit confused. The core clock and shader clock speeds can be linked or seperate. I'm enjoying this throughly.
When running Ntune it doesn't even show a shaderclock. Does this mean that Ntune doesn't alter the shaderclocks period or that it moves the shadersclock in the same manner as the linked setting?
I don't think I'm going back to Ntune but if it did link to the shader then it helps me know where my shader threshold is based on Ntune's performance.
