Originally posted by: beepbob
as I remember since when i bought it, it is amd athlon
Ha-ha-ha, there are very many Generations and Revisions of CPUs from AMD bearing the Athlon brand. 🙂
If you can't remember what you bought, use CPU-z to get information such as Model Name, Code Name and Specification.
Is 60C with the CPU under load, or at idle? If the former, it's probably OK; if the latter you should check CPU fan/cooling and Idle processes.
