<< Millenium - Mustangs are so overrated. I've seen numerous Integra Type R's and other (weaker) imports completely dust 'Stangs. Hell I know guys who lay the smack down on 5.0's with Turbo 4's and N/A V6's. My point is: mustangs are overrated. >>
Ok... then why does my friend run 9.80's in his 2000 Type-R? I am talking 1/8 mile. I ran 9.16 bone stock with my car and it is an automatic. With a few mods I run 9.03 with a mediocre 60ft. With Nitto Drag Radials, I will be able to cut my 60 ft from around 2.19-2.2's to 1.9x or lower. That would put me running anywhere from 8.80's to 8.90's. Also, I could do even better with some ET streets. If you know anything about drag racing then you know the difference between a 9.80 and a 9.03 is pretty large. My friend's 2001 z28 ran a 8.59 with just an exhaust cutout. The vette runs circles around the Type-R. Now let me answer your questions about 700 HP supras. I would say there are quite a few 350-425 hp supras, but I know from many readings on import forums, GM Forums, Ford Forums, etc... that a 700 HP wouldn't be a daily driver nor are they as common as 700 HP Fords, GMs or even Dodge. Achieving gobs of rwhp on a 99-01 Mustang GT is not as hard as you think. A novi 2000 running 10-12 PSI of boost in easily bringing 370+ RWHP to the new 99-01.
<< Just picked up the October issue of MM&FF. They put a Paxton Novi 2000 onto a Roush GT, that had the side exhaust, bassani x, kenne bell boost-a-pump, and a C&L 80mm mass air. The car made 404 rwhp @ 5800rpm
and 374 lbs.ft. @5100rpm >>
A Roush GT consists of mainly body kit, exhaust, k&n and a few other bolt ons. Let us look at the cost of a Supra(BTW is not longer made). A decent low-mid mileage supra still runs you anywhere from 25k and way up. Running as much boost as you need to get 700 rhwp requires forged internals and a lot of other engine work. The LS1 and the 5.0, have a lot cheaper parts than a supra. I would venture to say that a 4.6 modular has cheaper parts as well. If I wanted 400 RWHP right now it would cost me around 1000$. Port and Polish Heads, 100-150 shot of nitrous and slicks.
Lets compare the supra to a cobra. The cobra is still a lot cheaper but they are closer in stock performance than a GT. Numerous Cobras are making 450+ rwhp with a blower, a good tune and some bolt ons. I know a guy personally here in town with a yellow 98 cobra. 525 RWHP and the 1/4 in 10.86 spinning pretty bad. He is more than likely getting bigger slicks and maybe more boost. You want to compare GM? An LS1 with a turbo, or a blower, NOS, or even just a MTI heads and cam package will kill a Supra with BPU and Bolt-ons. A lot of the guys with the MTI heads and cams make over 400 RWHP. That is Naturally Aspirated! The package is not expensive either.
Anything else?
