Revving the engine when it first starts up, healthy or not?
thebestMAX
7,514
I love to listen to the idiots in the morning reving their engines like that!
I love the smell of napalm in the morning!
Dont idle for a long time either! Just drive normally until everything is warmed up and lubricated. Always read an engine is not fully warmed up for 7 miles. (Mostly to drive all the moisture from the oil there though)
CocaCola5
1,599
Originally posted by: woodie1
Originally posted by: CocaCola5
If you rev while in neutral/park its also not good(cold or hot), without a load piston speeds are MUCH higher than it should be thus more wear.
HUH?!?!?!
Without a load revving the engine makes it spin tons faster than its supposed to spin, stresses all the parts. I am talking mainly about revving to say 5-6K rpms just to hear the engine note.
CraigRT
31,440
let him damage or break the entire engine, and then laugh at him, and tell him i told you so... i don't have to explain what's right or wrong in this response... show him the thread..
Ferraro1
Think what Coca Cola might be trying to say is without a load applied, high revving can cause an oscillation in the pistons and crank, as the crankshaft eventually, at some threshold, will develop enough inertia to attempt to actually spin faster the pistons are being driven by combustion, and then dip below that threshold and inevitably lose that inertia, only gaining it back again after the next combustion cycle, where first the pistons are again being driven faster... this causes kind of a lash effect, a tug of war of forces within the engine that increases wear... would probably start to wear on crank bearings first, then as everything slowly loosened up, then rings, and cylinder walls... nothing ever actually moves faster than the other because the two are mechanically linked via connecting rod, so rpm = piston speed, at whatever conversion ratio applies given your particular crank circumference to piston travel length, but they will try to, given that the force being applied within the cylinder was meant to travel somewhere, and thus disperses throughout the engine via vibration even though it was designed to take it. I imagine this effect isn't noticeable unless you regularly exceed the redline for extended periods, and then cross back and forth between that line. They (used to anyway) do harmonics testing on engines to figure out at what rpms they started to hit their resonant frequencies and explode themselves. I'm pretty sure that goes into their redline determination as well.
Captante
30,354
10,880
Oh look...some moron bumped an 18 year old thread to try to impress us...
I've been saying it for awhile my guess is that most of these weird random necro's are some kind of bot/AI thing .... most likely designed to push advertising and/or BS information.
Seems like they're working on it ... right now its just annoying but soon when they get it right just like CGI in video you won't be able to tell if its a human poster or not.
Reactions: zinfamous
OccamsToothbrush
1,389
828
It's hard for AI to capture the right level of stupid. Can a machine blame everything on Trump, talk about fapping and argue about whether or not chili should have beans all in the same post? Any one of those sure, two out of three maybe. But all three? Nope, that's still years away.
13,917
Give it another 20 years and when this thread gets bumped again we'll be like "As if cars ran on internal combustion engines back then and had to be started manually! My Edison is warmed up for me by the time I leave for work, I just set the timer on my holophone before bed!".
Reactions: Captante
ElFenix
102,404
8,575
sounds like something a bot would say.
